setting up a backyard fabrication
7 Users
Re: setting up a backyard fabrication
Hello jennifer,
Post some pics naman ng equipment and machinery nyo..
Mukhang nakaka excite naman yang pag sset nyo ng fabrication
Ng hubby mo:D
Goodluck!;)
Posted : 27/06/2013 6:24 pm
Hello again Jennifer,
Yeah, hope you get a good deal with the power press machine you are looking for specially from the seller from Valenzuela City, a certain seller as 841967(Leo).
Good luck again !! 🙂
Posted : 28/06/2013 12:10 pm
(@jenniferdavid729)
Hi Rosy,
kulang ang number na nalakagay mo. hehe... sinasamantala ko na ang referrals m.
never ending thanks!
Jenny
Posted : 01/07/2013 10:15 am
(@jenniferdavid729)
Guys,
i was talking to afew powerpress supplier. unfortunately walang merong 10tonner, til i found one from sulit pa din. we checked na yesterday, 35k ung unit, AT AYAW MAG PA DICSOUNT :(, medyo kalawang na, kasi matagal ng di nagagamit. oltho kapag pundido naman daw ang bakal, matibay? hehe ang hirap ng hindi teknikal. basta nag GO ang husband ko, i will go for it also. plus ung stand pa sa kanan is bali ung bakal... mag fabricate nalang daw sila ng stand para dun. Not to mention it doesnt have motor, rubber and another accessory na nalimutan ko anung tawag...
ang hirap pala, first kapag limited fund kasi u can only go for second best(or worse).
anyway, may new tool kami. its makita js3200. cutter sya, 600watts. can cut(also in radius) up to 3mm. para syang mekanikal gunting, mabilis naman magtrabaho. bot it at mayon const sa binondo @21k. so far, so good.
hay nakakapagod pala!!! no more weekends. we are now finalizing the purchase for the bending machine.
its gotta be up to 8ft long and shud be able to bend up to 2mm. sana makahanap kami ng cheaper than 170k.
Today errands kami for the outsource cut to size. P15.00 kada bagsak ang charge nila.
KAYOD KALABAW MUNA KAMI... TALK TO YOU LATER 🙂
BEST REGARDS!,
jenny and rey
Posted : 01/07/2013 10:28 am
(@jenniferdavid729)
bdw, sige will post pics soon 🙂
Posted : 01/07/2013 10:29 am
