Air compressors
31 Users
 camv
(@camv)
Re: Air compressors
im planning to buy i saw this at sulit can any one help me understand the specs
Voltage: 220VAC, 60Hz
Motor Speed: 5500RPM
Max Pressure: 100PSI
Flow Rate: 20 L/Min @ 90psi
Rated Input: 176watts
Duty cycle: 100%
is this enough to do ducco? and cleaning power tools?
also it does not idicate how many HP how can i identify how may hp ?
The wattage rating is approx equivalent to 1/4Hp. It is a small compressor so I dont think you can use it for power tools cleaning for a sustained period. my 2cnts
Posted : 20/05/2012 10:53 am
(@vrcinfo)
Re: Air compressors
Just bought this today P6K. Slightly used Vespa 1HP from a dentist who is replacing it to a much quieter one. She was being complained in the condominium unit. This will be my main unit and will replace an Air Trade Brand from HMR and a 1/4HP Vespa.
I was baffled when a hose was connected on the drain plug. When I removed it the drainplug was replaced by a hose connector. I was thinking that this was done to connect a water separator/filter and as an outlet. That way she wouldn't be maintaining to drain the unit regularly and instead just the water separator/filter alone. May I ask if this is advisable and much better than connecting the water separator/filter in the original outlet (last image)? I'm planning to get a water separator/filter in the future. TIA
Posted : 30/09/2012 6:13 pm
Re: Air compressors
Looks good except for the missing belt guard.
As for the drain I'll just install the same shut off valve as installed in the top ( w/ red handle ) .. it is the same size fitting as the drain. If it turns out to be long then you could remove the valve threads on the output side to make it shorter. This way you can easily drain the compressor.
Lots of info on this thread below
http://www.pinoyhandyman.com/showthread.php?t=998&highlight=compressors
Posted : 30/09/2012 6:23 pm
(@vrcinfo)
Re: Air compressors
Wow that was quick bro. Thank you. There's a screen guard. It was removed because i made a general cleaning on the unit. I'll check the posts.
Posted : 30/09/2012 6:30 pm
Re: Air compressors
Congrats! You got an original Taiwan made Vespa w/c is very good. Restore the drain plug to its original function. You will really have to drain manually to check also if there is oil mixing in the tank not just rusted water. This will caution you if the heads or piston rings are starting to show wear. For the air outlet valve install a suitable air & water separator with a regulator before connecting to the hose to get clean air to the gun.
Posted : 01/10/2012 12:15 am
(@vrcinfo)
Re: Air compressors
Thank you very much Bro. Will follow your advice and find the necessary parts as you recommended. I hope this coming weekend i can go to Binondo. Will try to post the development.
Posted : 01/10/2012 6:12 pm
(@vrcinfo)
Re: Air compressors
Miller regulator/filter/separator (metallic filter) P1,200, Creston quick coupler set P250 at Suy Huat Hardware T. Alonzo.
Posted : 16/10/2012 10:32 pm
(@doitmyself)
Re: Air compressors
On the other hand, you may use the current drain host valve in your advantage. You can put a 150psi clear hose connected to another valve, in that way you can take away the water from the tank and you can see if you need to drain since the hose is clear. what do you think?
Posted : 16/10/2012 11:58 pm
(@vrcinfo)
Re: Air compressors
Thanks Bro, that's an excellent suggestion too. That way i can also redirect the drain somewhere else where it won't mess my flooring and my hands. Thank you.
Posted : 17/10/2012 4:08 pm
Re: Air compressors
Pa-hijack ng thread.
I will be taking the plunge and get myself a 2HP Vespa.
This came about because I am having difficulty strip planking my boat as I get to the more curvy part. My system of straps just requires too much effort already. So I ordered some plastic nails and a special pneumatic nail gun for it. Plastic nails are recommended for boats since they will not rust.
Now back to the Vespa.
Nailing requires little HP but, I thought, may as well get something that can multipurpose into painting. Read the threads on air compressors and some mods.
I plan to get it from Industrial Supply 143, same dealer where many of us got the Yamato welding machines last year.
Since I am a complete newbie when it comes to compressors, any tips on how I can quickly get started? Are there any required adjustments or mods on the get-go? Or would Vespa be, upon purchase, plug and play?
Posted : 08/01/2013 9:41 am
Re: Air compressors
GO GO GO Bro Ding, good decision/choice on where to get your original VESPA compressor, of course direct from the importer himself, Industrialsupply143. Better call first Ms Mimi to point you to their new warehouse address along Araneta Ave. which is the street behind BPI bank.
Their VESPA compressors are priced way much cheaper than ordinary hardware stores, home depots or mall hardwares, I have compared prices already before and Industrialsupply143 is above them all the cheapest. :2thumbsup: Baka maka discount ka pa !! :clap: :barmy: :naughty2:
Posted : 08/01/2013 10:22 am
Re: Air compressors
Salamat, Bro Rosy. Just by checking out Sulit, they are, indeed cheapest. Binanggit ko pangalan mo, nag-discount pa! 😀
I hope people here can give me tips to get started immediately.
Also delivery of my nailer and plastic nails will take more than a month. Baka mag-practise muna ako ng spray-painting. Hope people here can also give me tips to quickly get started.
Posted : 08/01/2013 10:36 am
Re: Air compressors
Two words:
:samurai:
Posted : 08/01/2013 11:25 am
Re: Air compressors
Once you get your compressor I think you can start practicing immediately or when you have the free time as long as you have the air hose, air gun sprayer, paint , thinner and cleaner. And along the way you can buy an air/water separator, aaaaahhhhhhhhh, what else, hhhmmm, better consult bro JayL for some other necessary attachments, or read the threads regarding air compressors. ;):)
Posted : 08/01/2013 12:57 pm
Re: Air compressors
Yeah get the compressor first then from there you can decide how to set it up.
I'm not sure if Mimi sells hoses and Filter / Water Separators.
Panda or LYS Hardware sells Acme and Milton quick disconnect respectively. Just be aware that there are a lot of quick disconnect standards and brands. It's best to stick with Milton or Acme.
A lot of info on air compressors documented here ...
Posted : 08/01/2013 1:45 pm
Page 3 / 7
