Air compressors
31 Users
phezthie
(@phezthie)
Re: Air compressors
many thanks sir rosy.
BTW, is E.Y. INDUSTRIAL SALES, INC. and IndustrialSupply143 the same company?
Posted : 16/03/2013 6:41 pm
Re: Air compressors
A BIG YES !! Only thing is Ms Mimi is not handling anymore IndustrialSupply143, a certain Joseph S. has been deligated, now handling the marketing aspect, Mimi got promoted if we may call it to a higher level of management, but she said she will still be supporting PHM members though she is already out of the marketing side.
Posted : 16/03/2013 7:29 pm
Re: Air compressors
Ditto on Rosy's comments re EY and Industrial143.
Got my compressor from them. Had a problem: adjustment of the relief valve. They were trying to explain to me over the phone how to fix it but decided it was better to send it back for adjustment. They did and topped up my oil in the process.
Very responsive.
Posted : 17/03/2013 6:39 am
phezthie
(@phezthie)
Re: Air compressors
^^ thanks for the clarification sirs, i guess it would be better if i will contact ms mimi first since im planning to buy 2hp vespa comp and yamato dc inverter too.. cheers to all
Posted : 17/03/2013 8:24 am
(@v-max)
Re: Air compressors
hello there,tagal ko nang naghahanap ng reliable air compressor at nasulyapan ko ang advertised na MAXSELL where I found your interesting site.di pa ko nakagamit ng industrial type,just a small one lang dati for airbrushing. I am currently working here in Saudi Arabia and very soon I will be staying sa pinas for good and I am planning to put up my wood-metal workshop might just be a hobby although I haven't got any experience on that field pero mahilig din ako sa DIY.when I found your site and start reading some threads,WOW! this is really for me.hardware shop is my jewelry and shopping mall talagang nakakatulo ng laway yung magagandang tools.thanks a lot for accepting me as a member.regards to everyone and more power...
Posted : 19/07/2013 12:25 pm
(@v-max)
Re: Air compressors
hi, does anyone knew about this air compressor brand?
聚才空压机官网,聚才,聚才空压机,JUCAI,JUCAI ...
Posted : 19/07/2013 12:40 pm
Re: Air compressors
If and when you get home and the time comes to buy your equipment try to get popular and well reviewed models. After sales warranty and product servicing are your most important concerns whether it's for DIY or business purpose. Most of us here have compressors and VESPA is just one of those popular brand that the locals prefer. There are many hi-end brands too but your usage has to warrant their price. Good luck!
Posted : 19/07/2013 1:20 pm
(@v-max)
Re: Air compressors
thanks sa payo master handyman...i'll take your advise and I will start searching for your recommended brand
Posted : 19/07/2013 4:04 pm
(@seelinkit)
Re: Air compressors
hello sir, im new to this forum. i just wanted to ask what are the usual causes of the motor of a compressor burning (producing white smoke)? by the way we are using vespa 1.5hp
Posted : 26/07/2013 10:18 am
Re: Air compressors
HI there seelinkit,
There are several factors or possibilities why a compressor burns out or becomes defective.
1. You could probably overworking your air compressor causing it to overheat.
2. Increase friction due to lubrication failure. You have to check your oil level regularly and never let it dry out.
3. If its emitting some white smoke, then their could be some winding insulation damage that leads eventually to winding burns. Better have it checked immediately before the entire motor and compressor stalls on you. 😮
4. Inadequate cooling and ventilation in and outside the compressor and location.
5. ETC...ETC
A little OT and REMINDER:
WELCOME, but since you are new here and this is your 1st post, could you please introduce yourself in the MEMBER INTRODUCTIONS, if you will scroll down the index page, its just under the GAZEBO Forum, easy to find. We'd love to know you better as a new member, do give us some info of yourself like where are you located, your hobbies or interest etc. Nothing really that is too personal. 🙂
Thanks,
Posted : 26/07/2013 1:03 pm
Re: Air compressors
Hello there too v-max,
Welcome to this very interesting site and community of pinoy diyers. Since you are a new member here and have enjoyed three post already, could you kindly introduce yourself in the MEMBER INTRODUCTIONS, its just below the GAZEBO Forum if you will scroll down the index page. Kindly give us some information of yourself, your line of work, your hobbies or interests that sort of keeps you busy during your spare time in Saudi Arabia. We'd love to know you better as a new registered member of this community. Well nothing really that is personal, just some infos in general, ok ?
Enjoy your stay sa PHM site plus we'll be hoping for your safe return here sa Pinas. 😉
Thanks,
Posted : 26/07/2013 4:18 pm
dadimak
(@dadimak)
Re: Air compressors
I got a 1hp belt-driven Vespa air compressor last Wednesday from E.Y. Industrial Sales, Inc. Now that weekend is near, I plan on working on it before I get to use it for auto detailing.
Here are my concerns:
1) What's the max PSI that I can set for it?
2) What oil will I have to keep on hand to lube it when the oil comes down?
3) What's the CFM for the unit that I got.
Finally, what are the things that I have to remember to keep it in good shape (aside from not actually using it... Haha!)?
By the way, I'll be using it mostly for auto detailing. My device requires 116-130psi so I'm thinking if I can max its pressure capacity.
Thank you.
Posted : 13/06/2014 10:28 am
Re: Air compressors
Si sir jayl makakasagot ng tanong mo brader..sya compressor king dito..hehe
Posted : 14/06/2014 11:21 pm
Re: Air compressors
Myself I own same compressor model.
I set mine at 110 to 115 PSI cut off
Shell SAE30 Monograde Oil
215L per minute ( you can google equivalent CFM )
Drain it of condensed water regularly.
What is this device or tool?
Thank you.
Install a pressure regulator and water trap.
Posted : 15/06/2014 1:25 pm
dadimak
(@dadimak)
Re: Air compressors
Thank you, sir JayL, for that information. I guess I'm good with 115psi. That's also the max that I set. Now I know that my compressor has approx 7.5cfm. I am draining it of water too everytime I finish using it. I get surprised at how much water accumulates after roughly three hours of using it.
By the way, my tool is a Tornador Black . Actually, it requires 8 to 9.6 bars. That's roughly 115psi to 130psi. But I can manage with what I'm currently getting. I can't buy a bigger one because I have to consider mobility in my auto detailing sideline. Anything bigger with my current one will mean that I'll have to get rid of my mobile service.
By the way, when I make use of my device, my compressor tends to recharge from time to time. For instance, when I'm detailing a sedan's interior, I use my device for roughly one minute then it recharges again. I continue using my device until the compressor's pressure reaches 6 bars then I rest my Tornador and allow the compressor to fully charge. My question is, how much time should I allow the compressor to rest before it should start recharging?
Thank you in advance. 🙂
EDIT: I am planning to use an extension cord that's about 10 feet. May I ask what specs of extension cord should I use. Thank you.
Posted : 16/06/2014 9:11 am
Page 5 / 7
