67 Users
(@rolly)
I recently got myself a Vespa 2hp compressor and learned a lot on how to correctly choose the correct one since there are countless imitation.
the motor specs...
and comes equipped with safety features...
the overall specs...
Timb, how much compressor mo? From binondo?
Posted : 23/05/2011 7:13 pm
Re: all about Air Compressors
not really sure anymore, but I think 14K maybe a bit less:glassesf:
Posted : 24/05/2011 12:08 am
I'm lokking for some back pressure check valves. Usually work with air and water.
I need these to connect compressors with different Max PSI ratings into a single main line.
http://www.kleen-ritecorp.com/p-1733-kleen-rite-maxi-flow-check-valve-5000psi-14fxf-ss-hp.aspx
Anybody knows a local source? Thanks
How about a local source of abrasive sand for sandblasting? If I could find a supplier then I could order this portable blaster and try it out.
http://www.zendextool.com/catalog/product_info.php?cPath=17_22&products_id=175
Posted : 24/05/2011 9:18 am
Guilder Galva Coat is not a high build primer. It lays down just like base coat.
Now what final color? Campbell Hausfeld Blue or Snap On Red?
Posted : 25/05/2011 7:24 pm
Could not paint today because it was raining. Just fixed the motor capacitor wiring.
Replaced the cheap connectors (? ). I forgot the proper name for this.
Which one do you think is a better color choice?
Campbell Hausfeld
or
Ingersoll Rand
Moji
Posted : 27/05/2011 10:13 pm
The white ones I think are generically called as crimp wire connectors and the orange ones are screw caps or wire nuts.
Campbell Hausfeld
I think that would this go more with your blue fittings...
Posted : 27/05/2011 10:35 pm
Thanks Jarod.
The Vespa 2 HP is a good compressor. What makes it cheapy is because the manufacturer cuts cost down by installing cheaper parts for wiring, painting, wheels, gate valves, intake filters, gauge, drain outlet, belt, screws etc... and a funky assembly job.
It has a good cast iron pump and 2 HP motor plus an 88 liter tank. Boost up pressure to 115 to 120 psi and it's still good to go. Charges fast and is reasonably priced. Spend and upgrade and you have a compressor nearer at par with US sold ( lowers ends are China anyway ) brand models within it's class.
Other people's opinions might vary ....
Posted : 27/05/2011 10:53 pm
Take for example the part I circled in blue. You can find a lot of these in the market and they all look identical. However upon closer inspection you will find that the good ones have thicker walls and better ball valve movement.
( pic borrowed from Timber )
This is how I came to know. All these defective and did not last and some more are in my junk box.
For Quick Disconnect I only use Milton brand ( LYS / Yale ) or Acme ( Panda ). All US made. I stay away from KYK, Lotus and the like which are pictured above. These leak air after some slight usage.
Posted : 27/05/2011 11:18 pm
I like the cleanliness the IR offers Jay...
and yes the ball valves are aplenty with quality in question, lucky me I came across that one, built like a tank, never gave me problems like the quick disconnect couplers from Panda(Acme) which are still US made. have seen other brands rust internally, dang...:blink::blink::blink:
Posted : 28/05/2011 2:00 am
Where did you get that one Timb? It looks different. Is it a Kitz brand?
tks
Posted : 28/05/2011 2:05 am
tks
not sure of the brand, but it looks solid thats why I got it. Sa T. Alonso yan brad, don't know the store name but I can go with you when you come over... tapos merienda tayo sa Lingnam:pope::pope::pope:
Posted : 28/05/2011 2:17 am
Will buzz you when I'm around the area. How much is it?
Looks like it's a female female so will need some gender changer to mount on a Vespa.
I did not see that one in your compressor install pics. Was it for the drain?
Posted : 28/05/2011 2:32 am
no, I use it sa open line ko... one with a coupler, the other uses that... sabihan mo lang ako a day before para hindi ako maglunch at makakain ng husto:massbounce:
Posted : 28/05/2011 2:36 am
Timb I thought you were suppose to organize a Binondo trip before. Maybe it's good chance for a group tool hunt.
Join na guys. Chance na ito for a tour from a guy who knows the place like the palm of his hand.
Moji tool hunting? Hehehhehehe
Posted : 28/05/2011 3:36 am
i will get this powercraft compressor this week but would like to know your opinion before the take.
http://www.sulit.com.ph/index.php/view+classifieds/id/513085/Powercraft+2.5hp+heavy+duty+air+compressor+%28vertical+type%29+new+design%21?referralKeywords=elektro
this will be used for my small spray painting booth..hehe..is the 9cfm enough for air gun with 1.0 to 1.5mm tips?
thanks po.
Posted : 28/05/2011 9:55 am
Page 13 / 25
