67 Users
Re: all about Air Compressors
I think this view ring window type applies mostly for single head piston models like Vespa or similarly built brands. If you notice for double pistons V-type or single in line they have dip sticks to gauge the oil depth. Some compressors I have noticed particularly the single piston Vespa perform differently w/ oils above the 5/8 level but this is just my experience. I agree on periodically checking the quality of oil.:)
I will put less oil on my Vespas on the next oil change. I think the 1 HP is due now.
Posted : 26/08/2012 2:40 am
archie013
(@archie013)
how do you know when to change the compressor's oil? should it be done every 6 months or every year? what specific type of oil should we use? thanks!
Posted : 26/08/2012 3:04 am
liteace
(@liteace)
mga sir may isa pa akong compressor na luma hanggang 45psi lang kaya niya .
mga sir anong klaseng compressor po ba ito?
nilalagyan din bato ng oil?
Posted : 26/08/2012 11:30 am
(@bigfoot2)
That seems to be a improvised compressor using the compressor of an airconditioning unit. Either loose compression, or the cutoff switch is set too low.
Posted : 26/08/2012 12:23 pm
(@sam_0115)
Galing nung conversion nun ah?!! 🙂
Posted : 26/08/2012 8:41 pm
Yes that compressor looks familiar, maybe its from an aircon unit or a refrigirator, hahaha, ang talas ng mga mata ni bigfoot !!!
Medyo OT lang ito bro !!
@ sam_0115,
It seems you are new here and have just joined PHM a few days back, bro, its been a customary practice here that you start by introducing yourself first before you can reply or join conversation, maybe you could tell us where you are from, what you do, your profession, your hobbies etc., you know a little backgrounder, we would like to know everyone here and so that you can be welcomed by the admins formally and properly. There is a forum here where you can introduce yourself, just scroll down the PHM index.
No offense brad, tip lang ito kasi all of us members here went also through that procedure/process.
SALAMAT PO !!!!!!!!!!!!!
Posted : 26/08/2012 9:43 pm
(@sam_0115)
Apologies sir rosy, i did not know nor read that it is necessary/must to introduce first before you join a conversation as this is not common as far as joining forums is concerned.
Just a suggestion, i think make it a "must" or "rule" for newbies to understand and comprehend. I also saw a newbie who introduced himslef but no welcome was given.
I'm also an admin myself in an automotive forum and to avoid this kind of confusion from happening all over again, make it rule so newbies would feel more welcome.
No offense din sir rosy, para lang din order ang lahat (my opinion po) since pareho naman tayong taga Rizaleno, I'm from San Guillermo, Morong, Rizal to be exact 🙂 , isang tambling sa bayan nyo 😀
WALA PONG ANUMAN!!!!!!!!!!!!!!!
Posted : 26/08/2012 11:00 pm
(@supaflay)
Hi guys
I recently inherited a very very old compressor from my late father- inlaw. I fixed everything up to the point it worked. I was able to use it with my nailer and paint gun. Recently i discovered a small hole under the tank. The size of the hole is like a small monggo bean. Can this leak be fixed or should i just buy a new one? Some say you can weld it. The tank is very rusty outside and i think inside as well. I hope someone will shed light on this. Thanks in advance
Posted : 28/03/2013 11:12 am
Even if you get that hole repaired, most likely there are other parts that are almost rusted through.
Continuing to use that tank is very dangerous. If I were you I wouldn't spend time and effort repairing that tank. I'd just have it replaced.
Google for images of "exploding compresor tank" and you'll see what I mean.
Posted : 28/03/2013 12:12 pm
I agree with Joey81 .... the danger it pose is not worth it. Don't use the compressor tank anymore.
Posted : 28/03/2013 5:56 pm
A very big plus + 1 to joey81 and JayL's response, better be safe than sorry in the end !!
Posted : 29/03/2013 10:37 pm
(@jolaz)
hi guys i'm planning to buy a 2hp vespa this week, can you tell me if this one is a legit vespa? /index.php/view+classifieds/id/15852040/Vespa+Air+Compressor?referralKeywords=vespa+air+compressor&event=Search+Ranking,Position,1-9,9"> http://www. ***********/index.php/view+classifieds/id/15852040/Vespa+Air+Compressor?referralKeywords=vespa+air+compressor&event=Search+Ranking,Position,1-9,9
my main use for a compressor is sandblasting. any inputs will be a big help.. TIA 😀
Posted : 09/07/2013 5:11 am
HI there Jolas,
Since you are a newly registered and a new member of this forum, can you please introduce yourself in the forum before you continue enjoying posting inquiries in the different topics/forums. Just scroll down the index page and below the GAZEBO Foum is the MEMBER INTRODUCTIONS, we'd like to know you better as a member, nothing really that is personal, perhaps your hobbies or interest and where are you located, etc.
THANKS,
Posted : 09/07/2013 11:10 am
(@jolaz)
My new toy
Vespa 2hp
Ok lang ba kung yung generic na THB brand na air filter/regulator ang gamitin ko?
can anyone recommend me a good quality hose reel that suit my 2-3k budget?
Posted : 12/07/2013 4:04 pm
(@fortnapz)
My new toy
Vespa 2hp
Bro, for your hose... US made "Swan" just pm JayL ... Amajay.com
Posted : 12/07/2013 6:37 pm
Page 19 / 25
