Spray Painting Talk
28 Users
Re: Spray Painting Talk
I would choose gravity myself.
Have you checked the post on the Creston Gun. Maybe we could ask the member for more feedback.
Posted : 06/06/2011 10:18 pm
I have no experience with gravity type but I already tried painting the ceiling using the suction-type spray gun.
Its a bit annoying because if you tilt the gun upwards too much it'll suck only air, especially if the can is already low on paint.
With the gravity type I think you can swivel the paint can, so you still have a continuous flow of paint even if you are spraying straight up.
Posted : 06/06/2011 10:22 pm
(@beedigo)
@ sir Jay,
Thanks, I'll try to search it later.
@ sir Joey,
Thanks for the feedback.
I'll see if I can get a cheap gravity gun tom. Thanks again guys.:thanks:
Posted : 06/06/2011 10:35 pm
(@andrew28)
ano bang magandang paint filter para sa exhaust at intake ng paint area para hindi gaano lumabas ang amoy? baka kasi magalit ang kapit bahay ko. thanks
Posted : 01/07/2011 6:58 pm
My friend was determined to buy a second hand 5HP Dual Stage 80 Gallon US Made Compressor. This was what he found.
Worthington. Needs a new pressure switch and a full paint job.
Compressor was dismantled at the sellers place for transporting. He paid 11K for it from a guy in Antipolo.
Posted : 18/07/2011 6:05 pm
wow !!!! make over lang ganda na yan 5hp hehehe ang lakas naman yan nice find sa sulit madami ka ding makikita good item
Posted : 19/07/2011 5:11 am
(@nikko-mercado)
hi guys,
im expanding my service center and im putting up a paint shop,im new to this kind of business,i already have a 5.5hp fini comp,my paint booth is almost done and now i am looking for spray guns.can you recommend a good but not so expensive spray guns?
Posted : 27/08/2011 8:27 pm
hi guys,
Just what the doctor ordered :cheekkiss: where are you located and what painting do you do? do you finish(not paint ha) wood as well? and what type of gun do you need (what will you use it for)?
Posted : 27/08/2011 9:02 pm
(@nikko-mercado)
oh sorry,its for automotive painting.
Posted : 27/08/2011 9:51 pm
What is your budget? There are many quality spray guns for auto finshing, from SATA, Iwata, DeVilbiss to Asturo, Finex, CATechnologies, etc. I think you can't go wrong with any of these..
Posted : 28/08/2011 12:41 am
Here you can find a lot of info regarding auto painting and finishing in this site.
http://autobodystore.com/forum/index.php
For midrange prices of spray guns you can probably look into the Devilbiss and Finex lines since you have the compressor to drive these guns.
You will need several guns or at the least tip sizes for Primer , Base Coats and Clear Coats.
http://www.tcpglobal.com/spraygundepot/devgate.aspx
http://www.tcpglobal.com/spraygundepot/sharpegate.aspx
For high end guns wherein budget is not much of an issue then Sata and Iwata seems to be on top of the game.
Posted : 28/08/2011 1:45 am
(@nikko-mercado)
sata and devilbliss is available in highlang trading,but its way beyond my budget,im looking for 3-6k sprayguns,:thanks:
Posted : 28/08/2011 9:09 am
(@nikko-mercado)
sir jayL,
what tip sizes can you recommend for primer,base and clear coats so that i can check it when looking for a spray gun.thanks
Posted : 28/08/2011 9:17 am
sir jayL,
Sorry I just saw your post now. None the less we're currently doing clear coating by panels ... hilamos.
We use 1.8mm or 2.2 ( high build ) mm for Primer, 1.4mm for base coat and clear. However I ordered another gun for clear with a tip of 1.3mm but have not arrived yet. For touch ups 1.0 mm tip.
The most tedious part in painting ... masking ......
Posted : 18/09/2011 2:48 pm
@sir JayL,
newbie here, how to hilamos po ba? 😀
Posted : 19/09/2011 3:00 am
Page 6 / 11
