Bugel's random projects
15 Users
Re: Bugel's random projects
It's a hanger hanger!
I dont know if it is worth sharing..hehehe..but my wife keep asking me to build this.
Notching 1/2 gi pipe using die grinder..
[IMG][/IMG]
I love this tool.. From enlarging hole,deburring,shaping metals and grinding hard to reach corner welds..this tool prove to be useful in my shop..bro miked iskor ka rin nato.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Posted : 06/08/2013 2:23 pm
Finding the center..
[IMG][/IMG]
Para balanse,,
[IMG][/IMG]
1x1 angle bar para sa paa..
[IMG][/IMG]
Spot weld lang front and back..
[IMG][/IMG]
Posted : 06/08/2013 2:30 pm
Can't take a good shot on this..ni rivet ko lang sa fence..
[IMG][/IMG]
Posted : 06/08/2013 2:39 pm
Mga de bayad projects..paa ng thresher..
[IMG][/IMG]
Simple welding bi pipe together..
[IMG][/IMG]
Tack weld..
[IMG][/IMG]
[IMG][/IMG]
Posted : 06/08/2013 2:54 pm
Full weld..
[IMG][/IMG]
Para hindi lumubog sa putik kailangan malapad ang base nya..
[IMG][/IMG]
5mm ms plate..
[IMG][/IMG]
[IMG][/IMG]
Posted : 06/08/2013 2:59 pm
1/8 7024 rod..ok sana yung unang layer ng weld nung inulit ko nagka bukol bukol tuloy.
[IMG][/IMG]
Sir jay eto yung welding rod na binigay mo sakin..medyo mahirap lang i re strike..
[IMG][/IMG]
Then drill a hole..para sa adjustment pag inangat ang paa..
[IMG][/IMG]
Oks na..
[IMG][/IMG]
Posted : 06/08/2013 3:08 pm
Welding gi pipe to cast iron..
[IMG][/IMG]
Sa patubig yata gamit to..
[IMG][/IMG]
Bumitaw yung previous weld( stainless )
[IMG][/IMG]
[IMG][/IMG]
Posted : 06/08/2013 3:14 pm
I grind down the previous weld then re thread the pipe..
[IMG][/IMG]
Then i mark it in the same position prior to welding para hindi mag kalihis ang butas kung san man i tuturnilyo to..
[IMG][/IMG]
Ang sabi ko sa nag papagawa bumili ng limang welding rod na pang pundido..bumalik isa lang ang dala..bakit kako isa lang? 140 pesos daw ang isa at pag kasyahin ko na lang daw..hehehe..
[IMG][/IMG]
I doubt kung tumagal din ang weld nato..ganado pa naman ako dahil makakapag praktis ako sa ganitong klase ng welding rod..
[IMG][/IMG]
Posted : 06/08/2013 3:28 pm
130 amps..tend to be having under cut in cast iron while on gi pipe it seems the penetration is low..
[IMG][/IMG]
There is no problem removing the slag..parang chalk lang..
[IMG][/IMG]
I apply epoxy steel to prevent water from leaking..
[IMG][/IMG]
Posted : 06/08/2013 3:40 pm
24 volts battery mount..
The owner change the battery of his 6 wheeler truck from 2sm to 3sm..so lumaki ang baterya hindi na kasya ngayun sa frame..
[IMG][/IMG]
Sa makatuwid gagawan ko ng bagong frame..
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Posted : 06/08/2013 4:05 pm
Eto nakakatakot na portion..ang pagtangal ng dating frame..my mga weld sa angle bar at plate na alanganin ang posisyon..
[IMG][/IMG]
Umipit yung wheel! Buti hindi nabasag!
[IMG][/IMG]
Ayan naka weld na ang bagong frame..
[IMG][/IMG]
[IMG][/IMG]
Posted : 06/08/2013 4:23 pm
Para hindi raw manakaw ang baterya..
[IMG][/IMG]
[IMG][/IMG]
Kabitan ng pad lock..
[IMG][/IMG]
Tapos na sana..nung idinidiretso ko naputol eto yata ang flat bar na made in china..
Parang pundido..
[IMG][/IMG]
Posted : 06/08/2013 4:32 pm
Re weld again:mad:
[IMG][/IMG]
[IMG][/IMG]
Natapos din..
[IMG][/IMG]
Posted : 06/08/2013 4:37 pm
Tack weld..
[IMG][/IMG]
Eto bro maganda din na tool for pipes ... auto adjust same like your CH Hanson 7CCS Locking Pliers.
http://www.amazon.com/Hanson-09500-9-Inch-Self-Adjusting-Locking/dp/B002GWVKWC/ref=sr_1_8?ie=UTF8&qid=1375780442&sr=8-8&keywords=ch+hanson+jaw+plier
O kung type mo alam mo na kung saan mo makikita yan ... hehehhe
Posted : 06/08/2013 5:14 pm
[IMG][/IMG]
Oks na..
OO nga mahirap mag re start ng drag rod kasi nakalubog yung rod ... so usually pag ginagamit ko me katabi ako na liha , file or bench grinder para alisin yun protruding flux cover.
Posted : 06/08/2013 5:26 pm
Page 2 / 10
