Bugel's random projects
15 Users
(@miked)
Re: Bugel's random projects
It's a hanger hanger!
I dont know if it is worth sharing..hehehe..but my wife keep asking me to build this.
Notching 1/2 gi pipe using die grinder..
[IMG][/IMG]
I love this tool.. From enlarging hole,deburring,shaping metals and grinding hard to reach corner welds..this tool prove to be useful in my shop..bro miked iskor ka rin nato.
[IMG][URL= .html]
walang problema.....basta ba ambunan moko ng pera.hehe....kainggit andami na namang bakal projects. 1 month nakong hindi naging man of steel.
Posted : 06/08/2013 8:56 pm
Bro bugel, for notching pipes, I use an angle grinder, I tried it with my die grinder, mas matagal at mabilis maubos yung grinding stones.
I suppose using a carbide tip de burring bits will do as well and faster. 😉
Posted : 07/08/2013 11:37 am
Sir jay sa dami ng wish list ko sa mga tools mo hindi ko na alam kung ano uunahin..:D
Sir rosy agree ako sa carbide burr..but lately ko lang nalaman na hindi pala fit sa die grinder ko yung 1/4 shank..6mm pala dapat..:(
Ok naman yung grinding stone na binigay sakin ni sir jay..tagal maubos,though medyo mabagal nga lang .
Sir jay baka may nilulumot ka nang 6mm shank na carbide burr jan..text ka lang sakin..hehehe..gusto ko talagang masubukan yan..
I'm a bit confused..may nakita kong grinding stone na naka set lotus yata yun..
Nakalagay sa label..(6mm-1/4 shank) kaya akala ko mag ka size lang ang 6mm and 1/4 shank:confused:
Posted : 07/08/2013 12:09 pm
(@miked)
eh yung bimetal hole saw pang-notch ng pipe pwede? may mga napanuod kasi ako sa youtube na mga DIY notching tools eh. hehe
Posted : 07/08/2013 5:20 pm
Nothing to be confused bro. 1/4" = 6.35mm.
If you're grinder is 1/4" collet then you might get away using 6mm shanks. However if your grinder has 6mm collect then it might be a bit difficult to force a 6.35mm shank.
Other people force it but for me I always prefer to stick with specs unless a modification is called for. After all that's the reason why they had those manufacturer parameters in the first place.
Not all die grinding stones and carbide burrs are made equal. For example the stones that came with your grinder are original Hitachi Japan stones. The grits are finer thus they chew away metal at a slower rate but with finer finish. The run of the mill grinding stones you can easily spot ... because they are consumed faster than the metal being ground or at worst the stone is the one being ground rather than the metal.
Quality carbide burrs are different. These chew metal like hot knife into butter. Available in Single Cut , Double Cut or Diamond style cutting profiles.
Then again the size and profile of the head will be dictated by the job to be pulled. For bigger sized carbide burrs and die grinding stones a variable speed die grinder is necessary. Each carbide burr and stone will have a speed rating and it's best not to exceed their max rpm.
Here are a few good 6mm carbide burrs.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=sgs+6mm+carbide+burr
There's a bit of a learning curve matching the profiles and sizes to the model number.
Posted : 07/08/2013 5:29 pm
Washing machine stand..
Nakabili ng bagong tool si misis..gawan ko raw ng stand.
Tack weld each corner..
I add extra square tube..para mas matibay..
[IMG][/IMG]
Eto nga pala yung dati kong stand..laging tumatambling tuwing hihilahin ko ang bakal..
Look at this shop built clamp. It looks like an excellent design. When I have chance I will borrow the concept and expand it a bit and build a custom one for my welding table.
Posted : 07/08/2013 8:49 pm
Pwedeng mag rotate ng 360 degrees,horizontal and vertical adjustment
Self locking din parang f clamp..thanks sir jay excellent design ba? Parang hindi naman..hehehe..
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Posted : 07/08/2013 9:57 pm
Yeah it's an excellent design for your table.
For my table it will need a bit of modification due to clamping issues. It should be able to slide in a bar as I can only clamp on the table edges. Maybe two of those arms on a flat bar long enough to be the same as my table width.
Posted : 07/08/2013 11:03 pm
(@miked)
may naisip ako bigla na paggagamitan nung mga pinagpalitan kong balljoints at tie rods a...hehe...ayos brader mahusay ka talaga pagdating sa bakal!
Posted : 07/08/2013 11:48 pm
Installing led light in my drill press
Pampatangal inip.. panay ang ulan kaya masarap mag kutingting..
I need to remove the belt cover para maluwag ang pag wiring ng ilaw.
Clockwise ang pihit ng quill pulley nut para lumuwag..hehe..kaya pala
Ayaw lumuwag pabaligtad pala ang ikot.
[IMG][/IMG]
I use a puller to remove the pulley..ayaw matangal sa pukpok lang..
[IMG][/IMG]
Then i need to removed the adjustment shaft of motor to lubricate and de rust,
Kaya pala nakikipagbuno ako bago ma i adjust kalawangin na pala.
[IMG][/IMG]
Tumatama sa shaft ang receptacle..kaya kailangang ibaba ang mount ng ilaw.
[IMG][/IMG]
Posted : 13/08/2013 7:24 pm
Welding 8mm nut in flat bar..dito ko i tuturnilyo yung receptacle..
Mas madali sana kung may pang tap lang ako..
[IMG][/IMG]
And here is my magnetic bowl..
[IMG][/IMG]
DIY style..hehehe..
[IMG][/IMG]
O ayan..tapos na ibo bolt na lang sa housing ng drill press..
[IMG][/IMG]
Posted : 13/08/2013 7:31 pm
I do a little painting today..some cover parts ng motor..para hindi naman boring tingnan..
[IMG][/IMG]
Oh di bah..mas ok kung two tone..
[IMG][/IMG]
Dahil jan..wala ng warranty..haha:p
[IMG][/IMG]
Posted : 13/08/2013 7:42 pm
O eto naman may magpapa bunot daw..
Wala kakong dentista dito..
Mag papabunot lang po ng putol na turnilyo:D
[IMG][/IMG]
Broken 10mm hexnut..as usual spot spot lang hangang meron ng kakapitan ang vise grip para mapihit ang wasted bolt..
[IMG][/IMG]
Magkano po pabunot?
Singkwenta pesos lang.
[IMG][/IMG]
Posted : 13/08/2013 7:54 pm
Quick n' dirty project..
Kaya dirty puro kalawang at putik..hehe
Posted : 20/09/2013 10:20 pm
Nag simula sa magnet matatapos sa magnet..
Ever useful sampayan..hehehe..
Posted : 20/09/2013 10:21 pm
Page 3 / 10
