Bugel's random projects
15 Users
Re: Bugel's random projects
then another tack welds using 3/32 rod..
6011 for root pass..medyo hirap akong gamitin to..
then filled it with 6013..U weave..
eto straight pull lang sa t joint..
Bro bugel, on the first two pics, perhaps you could have used your AC Yamato then followed it up with a 7018 rod instead of the 6013 rod, I do believe mas malakas ang kapit ng 7018 and then a cold pass of the 6013 very similar to the last pic on the fillet weld application. Well if it was me, yun ang sequence na ginawa ko. But if you think OK sa iyo at sa nag pagawa, then e di OK na rin yan.
Again bro, those are nice weld bead applications.
Congrats for a job well executed !!!
Posted : 22/12/2013 9:03 pm
thanks sir rosy..hirap dito samin 6011 at 6013 lang ang available na welding rod for mild steel..no choice sir..:( bihira naman ako mpunta ng manila para makabili..same price lang ba ng regular welding rod yun?
Posted : 22/12/2013 9:15 pm
(@Anonymous)
thi công sơn bả hãy đến DVN công ty chúng tôi chuyên thi công sơn bả, trang trí nội thất, ngoại thất với giá cả hợp lý nhất. hãy gọi cho dvn.vn chúng tôi để được giá tốt nhất 0916930381
Posted : 23/12/2013 8:39 pm
Bugel,
I sent you a PM. Did you get it?
WillyF
Posted : 29/12/2013 9:03 am
Posted : 17/01/2014 10:44 pm
Simpleng ihawan out of two pcs.3mm ms plate..
Madali lang gawin..
Para madaling I bend pinasadahan ko ng thin cutting disc yung linya..
Then bend..
Posted : 22/01/2014 7:00 pm
Weld all the corners muna..
Then full weld na lahat para matakpan ang gap..
Posted : 22/01/2014 7:02 pm
Tapos! :p
Posted : 22/01/2014 7:07 pm
amboy
(@amboy)
Ayos! 😀
Posted : 23/01/2014 6:25 am
(@fourtheboys96)
Ayos Bugel.
May balak din akong gumawa ng ihawan. Pamalit dun sa luma na ginawa ko nang walang welding welding hehehe.
Tanong ko lang:
- Anung klaseng metal sheet yan? black iron ba yun? definite hindi stainless o GI.
- Paano mo na-cut ang metal sheet?
Thanks!
Posted : 23/01/2014 10:52 am
Thanks mga bros..
@ fourtheboys, black iron plate..3mm ang kapal..angle grinder lang bro pinang cut ko using thin cutting wheel.
Posted : 23/01/2014 12:11 pm
Bro Bugel,
Amazing works like this still give me goose bumps. See this is why I wanted to try your skills on my project. By the way, I sent you an email. Kindly check if ever you have time. Tnx.:)
Posted : 23/01/2014 2:21 pm
(@fourtheboys96)
Thanks mga bros..
Thanks bugel!
Sent from my GT-N5100 using Tapatalk 2
Posted : 23/01/2014 2:43 pm
Thanks sir willyf..nakakataba naman ng puso ang comment mo..hehe..I read your email na nag reply na rin ako.
Posted : 23/01/2014 5:40 pm
Very nice.
Palagay ko madalas ang bbq party nyan!
Posted : 23/01/2014 6:28 pm
Page 7 / 10
