dog house build...take two!
8 Users
Re: dog house build...take two!
pag ganitong posisyon naman 120 amps para dikit agad..wag lang ibabad ang rod sigurado butas:p
3/4 plyboard..lalagyan ng dog bowl..
Posted : 11/12/2013 10:52 pm
Arf arf arf ......
Pipe clamps bro. I use the Pony 50 for clamping and the Pony 56 Deep Reach model for spreading.
Posted : 12/12/2013 12:37 am
spot spot lang..
100 amps..para patag ang latag ng beads..
Bro bugel, may I suggest if its OK with you to get in touch with joey81, see if you can have a box or two of the E7014 1/16" welding rods, baka may mga spare boxes pa sya. These 1/16" rods are great for thin sheet metals. I see in some of your joint weld nabubutasan parin, baka dapat 85 amps or 90 amps lang kailangan.
Suggestion lang naman !
Posted : 12/12/2013 3:12 pm
may order na ako sa kanya,di ko pa lang nakukuha..:)
Posted : 14/12/2013 9:20 am
natapos na rin..i apply galva coat primer..kinapalan ko sa floor frame area for long protection against rust..
the owner wishes that the roof can be detached from the frame..for what reason? i dont know..
Posted : 14/12/2013 9:45 am
I've set it aside. Sabihin mo lang kung kelan.
LOL! yellow fever!
para madaling linisin..nilakihan ko na rin ang pinto..
food and water bowl mount para hindi nawawala sa pwesto tuwing nag papakain..
may mini door din sya,para hindi na rin bubuksan ang malaking pinto kapag nagpapakain ng aso.
mas convinient di pa messy..
Posted : 14/12/2013 9:56 am
fabricated latch for the mini door..
wala pang dog mat..yung owner na lang ang mag kabit pag nakabili na sya..
thats all folks..thanks for viewing:)
Posted : 14/12/2013 10:03 am
phezthie
(@phezthie)
kainggit...sana boss bugel na post ma agad to para nagaya ko ...
tinest ko yung yamato, gumawa ako 2 kulungan ng "maso" (manok or aso) yang pakainan ang problema ko...
very nice bro...
Posted : 14/12/2013 11:14 am
Thanks bro pheztie..baka pwede pang i re build para malagyan din ng kainan..
Posted : 17/12/2013 9:39 am
(@mechpen)
sana sa loob ng garahe ilalagay yang kulungan na yan, dahil kawawa yung aso pag maaraw at maulan. sa craftmanship nyo sir bugel thumbsup
Posted : 07/01/2014 12:51 am
(@miked)
:rockon: man of steel bugel!!!
Posted : 07/01/2014 8:52 am
