I'm going to be busy..
9 Users
Re: I'm going to be busy..
May plano si misis kaya ayaw palagyan ng gulong.
You should let her read this thread, pati na rin yung sa kabila. ๐Ÿ˜€
Posted : 04/09/2013 10:06 am
Mukhang maraming nabubuong istorya itong bed frame mo bugel. Baka may mabuo uli ito pag ginagamit nyo na ni mrs.
Sent from my iPhone using Tapatalk.
Posted : 04/09/2013 12:54 pm
I used 1/16 ss welding rod to weld the shoe and to fill the hole as well..
For the top cover ms plate naman ang gagamitin ko,this will cut to four pieces using jigsaw with bimetal saw blade..
Angle bar for guide..
Straight cut..
Posted : 06/09/2013 10:19 pm
Im starting to loved this machine..cutting 5mm thick ms plate is a breeze..
After rounding the corners..
Ang tendency ng thin wall tubing pag na over fasten ng bolt mag create sya ng dimple or crater..to prevent that from happening i will make a thick plate support.
I use angle bar as a guide para mas diretso kung mag trim ng rough cut edges..
Posted : 06/09/2013 10:33 pm
Galing din sa 2x2 angular yan na ikinabit ko sa frame..walang nasayang na materials.
Posted : 07/09/2013 11:27 am
(@miked)
san ka nakascore ng 1/16 welding rod brader? hanap ko e 6013 kaso anghirap. SS 308 lang kadalasang meron.
Posted : 10/09/2013 9:52 pm
BRO MIKED,
Pa reserve ka kay bro joey81 ng isa o dalawang boxes ng 1/16 welding rods na 6013, namili sya duon ng mga Chicago Electric rods, he'll be coming home soon from the states. Check out his post on "Show your tool loot" .
GOOD LUCK !!! ๐Ÿ˜‰ ๐Ÿ˜€
Posted : 10/09/2013 10:08 pm
Heres the finished headboard and....ano ba tawag dito? Foot board?? Ewan ko bahala na kayo..lol!
Ready to prime and paint na..
Posted : 10/09/2013 11:44 pm
My paint booth..
And my under power compressor..
Posted : 10/09/2013 11:45 pm
Yup kay sir joey order ka sa kanya habang nasa u.s. pa sya..
Wala dito 6013 na 1/16 ang size..ang alam ko may iba pa
Syang items na pang metal working..pakulam ka na!:D
Posted : 10/09/2013 11:55 pm
Here's the painted frame..
Combination of jet black and pearl white..fine silver naman sa shoe at cover.
Assembling..
Posted : 11/09/2013 9:49 pm
These are the wheel casters that i will be using sana..baka masyadong tumaas naman kung ikakabit ko pa..
I end up using this floor protector..
Yan assembled na..lalagyan pa ng 1/4 plywood yung ibabaw para patag pag inilagay yung foam..dahil umuulan dito ngayon,bukas na lang..
With foam on top..
Haaay sa wakas natapos din...its time to relax relax muna..
Posted : 11/09/2013 10:04 pm
amboy
(@amboy)
Nice.... ๐Ÿ™‚
-ร—-ร—-ร—-ร—-ร—-ร—-ร—-ร—-ร—-ร—-ร—-ร—-ร—-รท-รท-
Yamato 200 Amp AC Arc Welder
Powercraft PIW201i 200 Amp DC Arc Welder
Makita 9556NB Angle Grinders
Bosch GSB16RE Drill
Bosch Power Sander
Dewalt Cordless Drill
Dewalt D7610 Chop Saw
Powercraft Auto Dimming Helmet
-ร—-ร—-ร—-ร—-ร—-ร—-ร—-ร—-ร—-ร—-ร—-ร—-ร—-ร—-ร—-
Sent from my Samsung Note 2 using Tapatalk Beta 4 for Android
Posted : 12/09/2013 12:38 am
:thanks: bro amboy..
1/4 plywood for the bed pan..cut to size..
Hindi kasya ang isang plywood,kaya dalawa binili ko..may natirang scrap na magagamit ko naman sa iba pang incoming project..;)
Posted : 13/09/2013 5:43 pm
Page 4 / 4
