39 Users
And all casters have been spot welded to the base and ready to be painted again to protect the welds from rusting.
Posted : 20/02/2013 4:08 pm
And finally assembled the whole washing machine base and ready to be installed once more.
Gave it to swmbo and she was so happy she won't be buying a new one, hehehe then gave me a loving kiss. Maybe I need to repair some more somethings in the house for swmbo and get more additional kisses in return. LOL 😀
Thanks for viewing this small project for swmbo !!
Posted : 20/02/2013 4:15 pm
@bro rosy,
sana ang ginawa mo ay nag install ka muna ng CCTV hanggang sa mahuli ang kawatan, then after mahuli e lagyan mo na ng grill hehehe nariyan pa rin yan at umaaligid aligid. nagbabasa ngayon ng PHM yan, nakikita lahat ng tools mo, type din siguro yung dewalt grinder mo hehehe
ang sarap gamitin ng DC welder kesa sa AC...smooooootttthhhh 🙂
HEHEHEHE, Thanks po sa advice sir Ossie, kaya lang instant reaction ko na agad to install a grill using the immediate available steel rods that I have, kasi baka masalisihan agad. 😮
Right you are, smooth start pag DC welder ang gamit compared sa AC welder. 😉
Posted : 20/02/2013 5:54 pm
Then applied some rust converter. I used to use Turco but now switched to this new chemical rust converter and stain remover, Turbo rust remover by Cord, since it works faster :cool01: , compared to the other brand that you have to dry it overnight after application.
heres mine sir rosy...same specs lang siguro ng turbo mo spray version nga lang to hindi pa nag iiwan ng white color sa metal.by the way pulido ka sir trumabaho:D
[IMG][/IMG]
Posted : 20/02/2013 7:27 pm
chopsaw stand/welder cart in one
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
wheels naman..tap and die the wheel shaft para madaling tangalin eto na rin ang magiging lock nya.
[IMG][/IMG]
Posted : 21/02/2013 12:44 pm
perfect fit yung 16mm corrugated bar sa wheel bearing pero kailangan ko pang i file yung washer para pumasok.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
ready to roll..
[IMG][/IMG]
Posted : 21/02/2013 12:53 pm
continuous spot weld to eliminate blowing holes to square tube..prone ako sa butas pag diretsong weld ang ginagawa ko.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Posted : 21/02/2013 1:03 pm
proper way of welding hexagon nut.
[IMG][/IMG]
[IMG][/IMG]
mas magandang gamitin ang stainless welding rod,patag ang resulta ng spot weld.
[IMG][/IMG]
[IMG][/IMG]
Posted : 21/02/2013 1:13 pm
pati square tube iba iba ang size pero 1x1.5 and 3/4 1.5 ang claim nila jan..
[IMG][/IMG
mix and match ko na lang yung nasa left side ang ginamit ko para mas konti ang clearance.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Posted : 21/02/2013 1:22 pm
kulang kulang pala yung mga pics ko..
[IMG][/IMG]
i made a swivel and clamping system under the top base so you can cut from 90 to 45 degree angle..
[IMG][/IMG]
it was sir jayL idea..sa kanya taas ang nag rorotate sakin naman sa baba..tutuo nyan nag tipid lang ako ng materials hehehe:D
[IMG][/IMG]
Posted : 21/02/2013 1:41 pm
Your chop saw stand bro will greatly increase your cutting capabilities .. ease, accuracy and repeatability. Bonus is less time for saw setup and cleanup.
Go go go ......:attack:
Posted : 21/02/2013 4:31 pm
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Ganda bro ng mga weld beads mo, really for thin tubing walls, hindi pwedeng isang pasada if using a stick welder, dapat pa isa isa, but that is different if one is using a Mig or a Tig welder.
Posted : 21/02/2013 8:05 pm
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Ayos yan bro bugel !!! Come to think of it, its great to know that "na nganganak" ang chopsaw stand project of bro JayL, truly it has become very useful for other metal boys.
Posted : 21/02/2013 10:31 pm
primed and painted..
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Posted : 22/02/2013 9:10 am
45..
[IMG][/IMG]
to 90 degree angle..
[IMG][/IMG]
Posted : 22/02/2013 9:14 am
Page 12 / 20
