39 Users
clayfigur
(@clayfigur)
Mga sirs, may Yamato DC 200A na din ako na portable. Kakabili ko lang last week dun sa shop ni sir joseph sa kapiligan...
Pasali sa thread na ito ha...
Posted : 13/05/2013 8:11 pm
Welcome to the "welding club"!
I'm sure you'll find that welder handy. I never built anything with mine (too busy) pero I found it useful pangkumpuni ng odds-and-ends sa bahay.
Posted : 14/05/2013 5:07 am
hehehe, IKAW PA !!!!! But of course bro clay, you are most welcome to contribute to this thread, matagal tagal ka rin na hindi naka pag post as a one of the metal boys, LOL
OK, we'll be looking forward to your new metal projects bro !!! :chopper: :groupwave:
Posted : 14/05/2013 8:56 am
clayfigur
(@clayfigur)
Mga sir, binaligtad ko wiring ng DC welder. Mas gusto ko kasi yung stick sa positive end, tapos low setting sa amperage.
Posted : 28/05/2013 10:40 am
(@boyalmiroljr)
Sirs after backreading seems everyone meron nitong Yamata DC 200A Inverter Welder. What are the pros & cons if I'll get this one instead un bulky ones na yamato. Thanks in advance!
p.s. What should be the surest line if sasabihin kay mrs na bibili ako nito? hehehe
Posted : 11/06/2013 10:05 am
boyalmiroljr ,
Bro Ronald, tell your mrs, you need this welder very badly so you can start doing projects for her and the house, so you won't be hiring a welder anymore outside of the subdivision. That you'd like to do repairs specially if it concerns metals like gates, window grills or maybe a puppy/dog house, kitchen cart perhaps or some garden furniture for her as well and so many more.
Bro, pros of the YAMATO portable weld machine, its very light and can be carried anywhere in the house, it can be plugged in any ordinary household outlet, can do the usual welding projects in mind, has a soft starting when making an arc, less spatters, less noise and less electric consumption. Its a good entry level for beginners and the price is very affordable for a DC welder, 1/3 or 1/2 the price vis a vis other DC welder in the market now. Seller provides good after sales service( proven several times na ) and discounts for PHM members. 😉
The cons bro, due to its size and lightness, it can easily be stolen, hehehe :D, you cannot use it for cutting metals, precisely for welding only, I personally find the ground and lead cables to be short for my use and the electrode holder is kinda crappy 😮 so might as well replace it so it can grip tight the welding rods properly.
Hope this helps bro !!! 😎
Posted : 11/06/2013 10:43 am
(@boyalmiroljr)
sir rosy, safe to plug in any ordinary outlet? I've checked my circuit braker mga usual amp per socket is 30a. ok lang po pag ganun? takot ko lang kasi baka may masira sa lines or appliances namin 🙂
Posted : 12/06/2013 8:59 am
(@spyghost)
whats you wire gauge?
Sent from my Cherry w500 using Tapatalk 4 Beta
Posted : 12/06/2013 9:49 am
(@miked)
wire gage ng yamato dc is 2.0mm iirc. nakatatak yun sa plug..but i'm using a 1.6 mm (gage 14) circuit which was used previously on a water pump. circuit breaker nya is 30 amp. so far hindi nagtitrip.
ngapala, nung una nung wala pa syang dedicated feeder line eh ginamit ko sa ordinary outlet with a 10 amp extension wire (gage 18 iirc). ayun sunog yung extension. akala ko nadale na yung unit ko.
to be on the safest side, bigyan mo na lang sya ng dedicated line matching to the gage no. of the welder. with a dedicated circuit breaker of course.
saka mo na lang gamitin sa common receptacle if the need arises.
hth
Posted : 12/06/2013 9:58 am
Yes Ronald, inverter welders now are made to be plugged in ordinary household outlets and that makes it really very convenient compared to the transformer types or the bulky ones that they still have to be connected or tapped direct to the main circuit breaker of safety switch box. The Yamato DC Inverter weld machine require an outlet socket of 10 or 15 amps capacity, like what you said, you have 30 amps circuit breaker per socket, so that if enough to power the Yamato.
hth
Hey bro miked, diba usually wire gauge natin sa mga outlets ng bahay ay gauge #12 and for our lighting fixtures ay gauge #14, so since these are the standard gauges, May I suggest you stick with the gauge #12 stranded wires for your extensions at huwag kang maging kompante sa gauge#14. Using the gauge #18 is too small/thin for a welder, :nono: they are only good for home appliances and some lighting fixtures.
Its better to be safe than be sorry, lalo na kung koryente pinag uusapan natin. :electricf:
Posted : 12/06/2013 11:53 am
(@miked)
yes, me too guns for safety...eventually papalitan ko rin yung dedicated feeder ko to gage 10 or 12 na stranded na. say 1-2 weeks time. weekends na lang ako makakapagweld for now. for the meantime ko lang ginagamit yung 1.6 mm diameter na feeder ng electric water pump dati. tska dahil yung mga outlet kasi sa loob ng bahay ay maluluwag na due to "ant invasion". plus the reason kung bakit ginagamit ko yung 1.6 mm na feeder ng water pump is mag-isa lang sya sa circuit breaker at outside the house yung mga connection pero may plastic enclosure naman yung breaker. if ever masunog (wag naman sana) or magtrip, sya lang ang madadale. papalitan ko na rin naman na yung poste ng breaker.
regarding sa gage 18 extension na ginamit ko eh one time lang yun at for a quick emergency weld sa lobas ng bahay na
i'll be installing also another 70 or 90 A breaker and gage 6 stranded sa bahay namin sa ilocos para sa AC welder and mini-shop use.
but one thing na nababasa ko sa likod ng dc welder, may nakalagay 30++ amperes. i suspect eto yung current draw nya at 100% duty rating.
Posted : 12/06/2013 12:35 pm
phezthie
(@phezthie)
di na acceptable as standard minimum wire ang 14 AWG sa electrical layout ...
BTT: mga masters, how much na ngayon ang price ng DC200 (pa PM nalang kung di pwede sa forum)? Im planning to buy na this weekend, convince na ako since wala pa ako nabalitaan bad feedback hehehe... Likewise, san ba ang landmark/place ng LYS? TIA
Update: Got my yamato unit yesterday... will start to practice this weekend..
Posted : 12/06/2013 7:01 pm
(@radjird)
sharing din po, my first ever try in welding...nakakatuwa din pala 🙂
Sent from Galaxy S3 using Tapatalk
Posted : 29/07/2013 10:29 pm
(@radjird)
oopps sorry sa "break-in" thread dapat
Posted : 29/07/2013 10:33 pm
@radjird,
You have to click and copy your PHOTOBUCKET uploaded image ( img ),the image code, once clicked it will turn yellow and indicate copied, then you go back to the thread you will be posting it, then click paste and the URL image code will be transferred and post the copied image. Try it !!
Hope this will help !!! 😉
Posted : 29/07/2013 11:15 pm
Page 16 / 20
