midnight club...
midnight club...
26 Users
Re: midnight club...
What screw length would be needed if using 2" thk stock?
Posted : 13/06/2010 10:58 pm
they often advise what is best to use, but if it were me, I'll probably use 3"...
Posted : 13/06/2010 11:01 pm
Musta mga sir? May mga UFC fans din pala dito. Was watching it also kanina while working on my temporary RT during commercial breaks.
Was able to finish mounting my GMR1 on my temporary RT (para magawa ko lang yung guitar rack). The acrylic sheet i used for the base plate is surviving the heat naman. I think that should do for now.
Good evening to fellow handymen and DIYers!
post pictures Dom, dito kasi no picture means it did not happen... 🙂
Posted : 13/06/2010 11:03 pm
(@mudhutdesigns)
Sige po sir. will take pictures tom. pero warning po ha. beginner lang ako sobra. as in barok barok pa gawa ko. dami pang kakaining kanin at ulam.
Posted : 13/06/2010 11:16 pm
ah don't worry Dom, be open to comments and criticism, it is what will make you better. that is how most of us started....
Posted : 13/06/2010 11:33 pm
(@mudhutdesigns)
ok sir. hope to learn a lot and improve my woodworking from you guys!
Posted : 14/06/2010 12:05 am
tulog si lidell... hahaha
Posted : 14/06/2010 12:38 am
Not Kreg-specific, but in general, should be
(thickness / 2) / sin(15) - screwhead_depth + penetration_depth
assuming exit hole at center of thickness
assuming 15 degrees -- somehwere I got the impression that Kreg uses 15 degrees
screwhead_depth = how deep screw head is buried below surface, measured along the hole
penetration_depth = desired depth of penetration in workpiece 2
This calculation is sensitive to the thickness value because 1/sin(15) is a big multiplying factor, so thickness value used should be appropriately accurate/precise.
Posted : 14/06/2010 8:47 am
(@rolly)
hahaha, nakaidlip, malas. . . 5 secs left in the round
Posted : 14/06/2010 10:33 pm
(@rolly)
kinakalawang ung kreg screw driver bit ko, bad trip. . ..
Posted : 14/06/2010 10:39 pm
dip in wd40 then wire brush?
Posted : 14/06/2010 11:10 pm
square drive screwdriver bit is available sa Panda....
Posted : 14/06/2010 11:33 pm
what's up to those who are?
Posted : 15/06/2010 2:05 am
learned how to use a scrub plane... woohooooooo
Posted : 15/06/2010 3:05 am
wanna practice? :p I need to square a lot of boards and scrub plane is the way to do it... ;);):p
Posted : 15/06/2010 9:13 pm
Page 24 / 67
