timber715 woodworks
timber715 woodworks
34 Users
Re: timber715 woodworks
Pasensya na. More questions. Nag-aaral pa kasi.
1. I can understand the "stiffen and stabilize" for sanding. Would ordinary cheap sanding sealers that come in those gin-bilog bottles achieve the same thing?
2. I recall you used to apply shellac using a ball of cotton cloth.now with a brush. Did you have to thin it more?
3. Does the shellac lessen the penetration of the stain? Or do you really sand thoroughly so the shellac just stays in the pits and grooves allowing the stain to still seep through?
4. If yes to #3, is there great risk that when sanding is uneven, you could have uneven staining?
5. I saw the screw you used as hinge in Video 2 before. Just thought baka you used a special one. Buti it doesn't come off after frequent opening and closing.
I'm surprised that
Posted : 14/01/2012 6:14 am
Pasensya na. More questions. Nag-aaral pa kasi.no worries brader :snow:
1. I can understand the "stiffen and stabilize" for sanding. Would ordinary cheap sanding sealers that come in those gin-bilog bottles achieve the same thing? yes it would but it would also give the wood a plasticy thick film unlike shellac wherein I can apply it in thin layers
2. I recall you used to apply shellac using a ball of cotton cloth.now with a brush. Did you have to thin it more? yes, it is thinned to act as a sealer. the nice thing about shellac.
yes to a degree and yes will work well as a grain filler.
4. If yes to #3, is there great risk that when sanding is uneven, you could have uneven staining? yes, that is why I am using a glaze.
5. I saw the screw you used as hinge in Video 2 before. Just thought baka you used a special one. Buti it doesn't come off after frequent opening and closing. no need for a special screw ding, I used a kreg screw with a neck portion that isn't threaded (it stays in the hole) while the threaded portion screws in the cover.
I'm surprised that
Posted : 19/01/2012 2:30 am
My box build video now complete... hope you like it :mellow:
Posted : 19/01/2012 3:08 am
 camv
(@camv)
Sir Timb this box is filled with suspense but the final outcome is a wonderful work of art! I feel like a Genie will come out to make my wish come true once I rub my hands on it:D
Posted : 19/01/2012 5:01 am
Work of beauty. Was that gloss lacquer you applied last?
I have the same sander. Did you use a buffing pad? Didn't know you can attach one to it.
Posted : 19/01/2012 5:26 am
yes I did Ding, 5 stage buffing yan... from 400grit soft pad to 3000grit. the finish is gloss poly only......
Posted : 19/01/2012 5:54 am
:2thumbsup::2thumbsup::2thumbsup::2thumbsup:
pang exhibit ang beauty !!!
Posted : 19/01/2012 6:10 am
Nice job Timber...new and unique design..newl look..great finish! :thumbup:
Posted : 19/01/2012 9:23 pm
(@willy1467)
Ang ganda Sir Timber ng latest masterpiece mo.
Like Sir Ding, I still have to master the art of fine finishes on my projects.
Kaya lagi ko binabalikan yung mga previous posts mo.
Posted : 19/01/2012 9:37 pm
salamat braders....
eto for Chisel.... link
Posted : 20/01/2012 2:55 am
Very very nice and informative LINK for making wooden screws and taps plus the other videos the goes with it.
I personally find these videos very exciting, the tutorials, very informative and relevant.
Thanks timb for sharing this link, kaya lang, kaya lang, bakit para kay chisel lang ? HEHEHEHE
Posted : 20/01/2012 9:25 am
trying my hand at making a cpu case for a computer I intend as my audio source...
pieces cut to size and cut the mortice and tenons...
Posted : 21/01/2012 12:51 am
dry fitting.
and checking that the motherboard fits...
Posted : 21/01/2012 12:55 am
then I cut the material for the sides and the front...
again making sure the board still fits.
the outer portion? it does look good...
and with the front portion fitting, they match nicely...
now whether this will work or not, I do not know yet.
Posted : 21/01/2012 1:00 am
Very nice. A computer disguised as furniture!
What are you doing for ventilation?
How about the sockets (e.g. video, audio, etc)?
Posted : 21/01/2012 6:55 am
Page 13 / 18
