timber715 woodworks
timber715 woodworks
34 Users
Re: timber715 woodworks
temporarily closed.... I got the flu. huhuhuhu
Get well soon Master..;)
Posted : 25/10/2011 7:48 am
Get well soon, master timb! Marami ka pang kukulamin. 😀
Posted : 25/10/2011 8:37 am
WHAT ?? IKAW MAY SAKIT ?? Akala ko hindi ka tinatablahan ng sakit, lalo na yung mga nang kukulam !!!!!!! EHE HE HE HE HE HE HE , JOKE JOKE JOKE TIMBS.
Anyway bro, drink plenty of calamansi or dalandan juice, bombarred your body of lots of VITAMIN Cs to regain body resistance and strength and try changing your sleeping habits bro, pag nag kaka edad na dapat eh early to bed na so that early to rise na lang. Maybe your body resistance dropped because of laging puyat, LOL
Bro, get well soon.
Posted : 25/10/2011 10:53 am
thanks guys, it must have been due to the extra load :fetch1:.... though today seems like a good day, I feel much better than the past 5 days...
Posted : 25/10/2011 11:48 am
first day back to work after a refreshing break. I got the legs done and test fitted.
I even had time to make a dumbbell.
Posted : 03/11/2011 1:46 am
(@josefino-sianghio)
Good afternoon Timber!
Last time you said that the John Benzen jointer is ok to buy if it is checked to be coplanar.
It's only 1-hp and the seller said it might not be suitable for really rough stock. It's for finer milling. He's
recommending a Taiwan-made jointer with 2-hp motor but it's double the price. Should I not
settle with the 1-hp machine since I would always be dealing with roughly power-chained boards?
Please advise.
Thank you.
Jojo
Posted : 04/11/2011 2:12 pm
Please advise.
Thank you.
Jojo
Jojo, would you be working with rough lumber? sana you can post the prices of both jointers and pictures if you have them. to begin with, I still do not have a jointer of my own though Chisel has a John Benzen that he is happy with, knowing the guy, he does crazy work with rough and even green stuff.
I think the 1Hp would be fine unless you want to do heavy cuts in one pass. making shallow cuts should not be a concern with the smaller motor, it will only require you a little more work making more passes.
Question: are these 6" jointers? have you come across 8" ones? I'm already on the hunt for one myself but I think I would like the wider capacity.
Posted : 04/11/2011 2:20 pm
Thank you for the your prompt reply and advice.
I've seen only the 6"-jointer which is P16,500 - last price. Sorry I don't have a picture but if I would describe it, it has a bed length of around 1 to 1 and a half meter only; and has a guide rail. The unit I'm talking about has a slightly dented and rusty cover at the side probably due to mishandling - but it can be repainted. The cost of the 8" is between P65 to 85,000 (Torq and Golden Bell Marketing, respectively).
Ok na siguro yung 6", mura kasi.
I hope you can find also the jointer that you like.
Regards.
Posted : 04/11/2011 3:06 pm
Jojo, what I really look ffor in a jointer is definitely a flat coplanar bed and I want it long both infeed and outfeed.
got some work done on the second audio rack for the show.
napagtripan ko rin ito...
Posted : 05/11/2011 12:32 am
leaving everything in glue stage, will work on it bukas again.
Posted : 05/11/2011 12:36 am
That'll be one tough sanding job.
Excellent work, as always, Timb.
Posted : 05/11/2011 5:59 am
thanks Ding, sanding really won't be much of a hassle since the chair is small.
had an hour to work on it
decided I'll do a little sanding but before I do, I decided to raise the grain and wet the surface. This process will also give me an idea how it will look when finished.
some closer view of the joints (pleas bear in mind this is still prior to sanding and some glue will still be on it)
the center stretcher.
the stretcher to the leg.
Posted : 05/11/2011 9:24 pm
the leg to the top.
hope you're liking it, it sure is a fun build so far....
Posted : 05/11/2011 9:25 pm
Did you say chair?
I thought it was one of those Chinese flower pot tables.
Posted : 05/11/2011 11:55 pm
Did you say chair?
hehehe that will work... but this one is intended to be my shop stool.... I need an adjustable height seat ya know:p
Posted : 06/11/2011 12:26 am
Page 6 / 18
