JayL's Garage Tool Shop
2 Users
Re: JayL's Garage Tool Shop
Posted : 13/07/2013 12:54 am
Posted : 13/07/2013 12:55 am
These 2 boxes ( regular and long item ) are suppose to arrive this week. However due to random inspections by US Customs there was a delay. The shipment was released from them last June 10 and will probably arrive Pasay City 2nd or 3rd week August.
For those that are expecting orders then please note the delay. I apologize as it is beyond my control.
3M Peltor H10A Optime 105 Earmuff, 105 dBA
Bessey WMS-4 Double Magnetic Square
Bessey WMS-7 Arrowhead Magnetic Square
Bosch ROS20VSK 120-Volt Variable Speed Random Orbit Sander Kit
Celtic Woodworking Projects Book
Freud D0760X Diablo Ultra Finish Saw Blade ATB 7-1/4-Inch
Freud DS0012S Diablo Bi-Metal Value Pack, 12-Piece
GUNDLACH "J" ROLLER FOR PLASTIC LAMINATE - J200B
Hyde 43521 Support Painters Pyramid
Ingersoll Rand Air Hammer 114GQC
J-B Weld 8267-S J-B Steel Stik
Jorgensen 50 Pony 3/4-Inch Pipe Clamp Fixture
Kreg 675 Screw Kit
Kreg K4MS Pocket Hole Jig Kit
Kreg NZ03 Magnetic Drawer Slide Mounting Tool
Kreg NZ03-B Drawer Mounting Brackets
Kreg Tool R3 Pocket Hole System
Lisle 63250 Wide Range Oil Filter Wrench
Lisle 63600 Oil Filter Wrench
Mayhew 2 Piece Dominator Weld Wakker Chisel Set
Micro Jig GRR-Ripper Advanced Model 200
MLCS 8377 15-Piece Router Bit Set with Carbide-Tipped 1/2-Inch Shanks
Pony 56 2-1/2" Deep Reach Clamp & Spreader Fixture for 3/4" Pipe
PORTER-CABLE 5553 Plate Joining Biscuits "20"
Rockler Universal Fence Clamps
Sharp EL-2196BL Heavy Duty Color Printing Calculator
Titebond III Ultimate Wood Glue, 32-Ounce Bottle
Unitec Gravity Feed Speedblaster - USA
Woodpeckers 4" M2 Box Making Clamp
Woodpeckers Coping Sled
Woodpeckers Mulit-Knob, 1/4"-20, 4-Pack
Woodpeckers Precision Square, 12" x 8"
Woodpeckers Rule Stop 1" RS-1
Woodpeckers Straight Edge Rule, Aluminum, 24" SERXL-24
Woodpeckers Variable Pressure Featherboards (Pair)
WoodpeckersT-Square 24" TS-24-2
Quantities will vary.
Posted : 16/07/2013 6:47 pm
This shipment is also at the US Customs but has not been released yet.
Brown & Sharpe 599-767 8 Piece Hardened Steel Drive Pin Punch Set
Freud D1080X Diablo 10-Inch 80-tooth ATB Finish Saw Blade
Kreg KHC-PREMIUM Face Clamp
Freud LU87R010 10-Inch 24-Tooth FTG Thin Kerf Ripping Saw Blade
DeVilbiss 802343 - StartingLine HVLP Paint and Primer Spray Gun Kits
Shark Corp 10-2410 Fine-Cut 19-Point Finish Saw
Kreg KHC-RAC Right Angle Clamp
Actron CP7828 Professional Compression Tester Kit
J-B Weld 8272 Marine Weld
Marvel MM85R1-6PK Air Tool Oil - 32 oz.
Franklin International 1415 Titebond III Ultimate Wood Glue
Franklin International 5005 Titebond II Premium Wood Glue
Craftsman Miter Clamp Set
PORTALIGN PRECISION DRILL GUIDE
Bosch CC2430 3-Piece No. 6, No. 8, and No. 10 Self-Centering Bit
Bosch CC2460 Clic-Change 7-Piece Phillips Bit and Countersinking Set
Bosch TS1002 Table Saw Rear Outfeed Support Extension
Bosch TS1003 Table Saw Left Side Support Extension
GoodYear 045 3/8-Inch-by-50-Feet Safety Yellow Rubber Hose
Snap-On 870214 Rubber Air Hose, 3/8-Inch x 50-Feet
Equus 3551 Xenon Inductive Timing Light
Posted : 16/07/2013 6:54 pm
Several boxes still being prepared for shipping or are now loaded in the containers. I would update again later.
If you want items to be kept on stock then let me know and I'll see what I can do.
Posted : 16/07/2013 6:56 pm
