DIY Givi Box Bracke...
DIY Givi Box Bracket
12 Users
Re: DIY Givi Box Bracket
please take proper precautions when spraying urethanes..those most often than not contain isocyanates. Pretty dangerous stuff from what i've read..
Posted : 20/04/2011 12:57 am
thanks for the info moji. i really appreciate your concern very much.
primered:
Posted : 20/04/2011 5:42 pm
my paint mixing glass:
Posted : 22/04/2011 5:28 pm
Posted : 22/04/2011 5:29 pm
removing the orange peel/flattening the base coat.
Posted : 24/04/2011 12:33 am
after the top coat:
w/o flash:
with flash:
Posted : 24/04/2011 9:29 am
w/o flash:
with flash:
im thinking if im going to wet sand and buff the top coat or not 😮
hmmmmmmm
Posted : 24/04/2011 9:35 am
decided to finish the procedure hehe
wet sanding:
my polisher: im using variable speed angle grinder.
warning: not recommended to high rpm angle grinder:
Posted : 24/04/2011 1:43 pm
using 3M rubbing compound:
somebody said that you can apply wax after a week, but i decided to apply it after the rubber compound buffing process
using Turtle Wax:
after wax application:
w/o flash:
with flash:
Posted : 24/04/2011 1:50 pm
w/o flash:
with flash:
Posted : 24/04/2011 1:51 pm
(@andrew28)
the part that i dont like hehehe wet sanding.
sir ossie, gaano katagal papatuyuin ang base coat before i can wet sand it?
Posted : 27/06/2011 1:21 pm
bbn
 bbn
(@bbn)
Nice job! I especially like that bender, I've got to make me one of those.
Posted : 28/06/2011 8:19 am
i usually wet sand the base coat (even the primer-if needed, and the top coat) the following morning, but sa instruction pwede na sya within 5 hours yata hehe
thanks master handyman, yup, the bender is really helpful, a must for a metal worker like us 🙂
Posted : 08/07/2011 11:11 am
(@Anonymous)
nice bracket sir.... nicely done... one thing lang boss
im kinda worried about the strength dun sa may pinagturnilyuhan =)
same issue i had with my fabricated givi bracket...
dalawang beses naulit na tinibayan yung connection / weld
dun nag fail din sa part sa dulo.. where the round bar meets with the hole kung saan nakaturnilyo..
or maybe i just carry too much or ride really hard =
Posted : 04/12/2012 7:12 am
liteace
(@liteace)
w/o flash:
with flash:
i post mo sa mcp yan sir
Posted : 04/12/2012 8:52 am
