135gal aquarium/upg...
135gal aquarium/upgraded to 160gals
10 Users
Re: 135gal aquarium
Yup PALHS. I also posted there this build.
The stand im building is not a fine woodworking project. I did not employ fancy joints. All this needs to be is robust and stable.
Posted : 10/07/2010 8:34 pm
(@mudhutdesigns)
Re: 135gal aquarium
That's my main concern talaga. I might not be able to build a structurally sound aquarium stand.
OT: So what do you plan to put in it? Will we be seeing a super red arowana or a 24k golden crossback? I'm into exotic bichirs (dragonfins). I think Ben is into hardcore planted tank by the looks of his tank. 🙂
Posted : 10/07/2010 9:34 pm
Re: 135gal aquarium
Im almost sure that an arowana will be placed there. I have a bichir and oscar. They will probably be placed there too. It will probably be a comm tank hehe..
Posted : 10/07/2010 10:05 pm
(@mudhutdesigns)
Re: 135gal aquarium
The tank looks promising as the aquarium stand itself.
Posted : 10/07/2010 10:15 pm
Re: 135gal aquarium
Thanks..i do hope it all goes well..if not its 135 gallons of water on the floor!
Posted : 10/07/2010 10:43 pm
Re: 135gal aquarium
@Moji
Are you using fine threaded local screws? I think the course one are for plywood and the fine ones are for hardwood.
http://www.amazon.com/Kreg-SML-C125-4-Inch-Coarse-1000-Pack/dp/B00002240N/ref=sr_1_1?ie=UTF8&s=hi&qid=1278773615&sr=8-1
http://www.amazon.com/Kreg-SML-F125-1000-4-Inch-Pan-Head-1000-Pack/dp/B0006444U2/ref=sr_1_4?ie=UTF8&s=hi&qid=1278773615&sr=8-4
Posted : 10/07/2010 10:54 pm
Re: 135gal aquarium
The screws i got locally don't have fine threads. I did read that the fine threaded screws are made for hardwood, im just lucky that the wood i used did not split or crack. I guess the self-tapping point helped.
Posted : 10/07/2010 11:16 pm
Re: 135gal aquarium
Got the legs done
I was doing the legs right before the storm hit..got caught with the brownout..luckily i was using the cordless..
I really love that drill..no regrets in buying it.
Installed the legs into the bottom frame
Posted : 15/07/2010 11:57 pm
Re: 135gal aquarium
seems to be a legs day... :p:p
Posted : 16/07/2010 12:36 am
Re: 135gal aquarium
More WIP's
Started skinning the frame with the plywood.
Attached top and bottom together
Posted : 24/07/2010 9:52 pm
Re: 135gal aquarium
I dry fit the outer plywood skin and then i noticed a problem..
One side of the aquarium is off square by around 1/4". I think this moved when i was fastening the other side of the frame. Now will this be a major problem?
Posted : 24/07/2010 9:54 pm
Re: 135gal aquarium
seems fine from where I'm at. your problem seems just cosmetic and can be corrected easily by adding an edge band and lanning from there...
Posted : 24/07/2010 11:17 pm
Re: 135gal aquarium
Oh i forgot, on the right side of the ply, sobra naman yung plywood by 1/4".. is this still considered cosmetic?
Posted : 25/07/2010 12:05 am
Re: 135gal aquarium
out of square nga either the plywood or the frame, see how much out of square if you have a protractor.
Posted : 25/07/2010 12:22 am
Re: 135gal aquarium
Its the frame. i think the top and bottom on this side did not align properly. Hmm..delikado ba to?
Posted : 25/07/2010 12:26 am
Page 4 / 7
