135gal aquarium/upg...
135gal aquarium/upgraded to 160gals
10 Users
Re: 135gal aquarium
Its the frame. i think the top and bottom on this side did not align properly. Hmm..delikado ba to?
try this, ask your brother, your mom and aunt and you sit on it and see if it is stable. no need for movement since your tank wouldn't have waves...
Posted : 25/07/2010 12:30 am
Re: 135gal aquarium
Its off by around +-2 degrees. My gut tells me it would hold.. i'll see if i can get the stand down from the sawhorse and get all of us on top of it...Its now very heavy..
Posted : 25/07/2010 12:44 am
Re: 135gal aquarium
Ive seen in fish forums , tank stands built with ALOT LESS care. Not to mention aquarium stands same size as yours built by folks with lesser experience than me. Then i have lesser experience than you. 🙂
The bottom (feet/foot the thing that touches the ground) of my tank is scattered with those anti scratch rubber stick on things. It also has the side effect of leveling. you could consider that. Oh there is a felt tip instead of rubber tip. The felt tip gives me the ability to "slide" the aquarium tank stand a little bit at a time. 🙂
Posted : 25/07/2010 9:02 pm
Re: 135gal aquarium
Im also thinking of those leveling pads, my only concern is that it might degrade over time or might get squished too much thus rendering the aquarium unstable. I might try wood shims..
Posted : 25/07/2010 10:51 pm
Re: 135gal aquarium
Its been a while...the weather has been so weird that i wasn't able to get to work much last week..
Cut the styro to size before closing of the top
Posted : 04/08/2010 5:58 pm
Re: 135gal aquarium
Im about done with the plywood skin and edging..only the doors need to be done..
Posted : 04/08/2010 5:59 pm
Re: 135gal aquarium
looking good bro...
Posted : 04/08/2010 11:21 pm
Re: 135gal aquarium
thanks..hindi na ko nakabili ng nail gun..ubos na pla budget ko hehe
Posted : 04/08/2010 11:25 pm
Re: 135gal aquarium
tagal ng update ah?....
Posted : 11/08/2010 12:41 am
Re: 135gal aquarium
Some updates..
Got to work on the cabinet doors..
placing the edging
installing the concealed hinges
Doors installed
Posted : 11/08/2010 12:58 am
Re: 135gal aquarium
plywood door naman pala eh, madali lang ayusin yan... hahahaha.
nice work bro, its beginning to look like a cabinet... :p
Posted : 11/08/2010 1:41 am
Re: 135gal aquarium
Took a while before i was able to finish the masilya stage. The sanding part i did not like at all but is needed for a good finish. Took about a week, notice i did not put masilya on the back inner wall. It will be barely seen anyway.
Got to start putting the primer on. The weather changed so fast that i was not able to put on the exterior. Interiors and door only
Posted : 25/08/2010 2:17 am
Re: 135gal aquarium
lacquered yan Moji? very nice...
Posted : 25/08/2010 9:32 am
Re: 135gal aquarium
The masilya is lacquer based, but the primer, paint is enamel..
Posted : 26/08/2010 1:57 am
Re: 135gal aquarium
Hi sir moji,
So pwedeng ganitong combination? All along I thought that lacquer and enamel could never be applied together as it will result to paint deterioration. Or dahil masilya naman yung isa and not a paint itself kaya ok lang?
Thanks in advance for your explanation.
Posted : 26/08/2010 11:40 pm
Page 5 / 7
