135gal aquarium/upg...
135gal aquarium/upgraded to 160gals
10 Users
Re: 135gal aquarium
the thing is Jarod, that the enamel will not react on a lacquered based finish, but not the other way around. applying a lacquered finish over and enamel paint will give you disastrous results...
Posted : 26/08/2010 11:54 pm
Re: 135gal aquarium
I think it depends on the drying time of the two paints. Timber is correct in saying that you can apply enamel over lacquer but not vice versa. Enamel fully cures a very long time while lacquer cures very fast. Defects occur when the bottom layer is still curing while the top has already dried.
Posted : 27/08/2010 12:37 am
chisel
(@chisel)
Re: 135gal aquarium
Moji quick question, I’m going to paint our ceiling and I’m going to spray finish it because of the crown molding to buy me some time. What would you suggest for primer that can go for spray painting. TIA
Posted : 27/08/2010 7:13 am
Re: 135gal aquarium
What type of paint would you use? If spray painting then i would think that lacquer is the appropriate paint/primer to use.
Posted : 27/08/2010 12:54 pm
chisel
(@chisel)
Re: 135gal aquarium
Moji What is your recommendation in painting a ceiling
Posted : 27/08/2010 10:23 pm
Re: 135gal aquarium
The usual method is enamel applied by roller..
Posted : 27/08/2010 11:29 pm
mek
 mek
(@mek)
Re: 135gal aquarium
nice build! i'm a tank builder myself and currently on a project. and yes i will agree on you with the sanding part... hehe. good luck sir sa project nyo.
Posted : 01/09/2010 9:08 pm
Re: 135gal aquarium
thanks, do post pics of your work. Im quite interested in your projects..
Posted : 01/09/2010 11:14 pm
mek
 mek
(@mek)
Re: 135gal aquarium
sige po sir. perhaps i'll just post it here kasi i think i'm not allowed yet to post links. btw, ano nga po pala waterproofer gamit nyo?
Posted : 01/09/2010 11:16 pm
Re: 135gal aquarium
you can post pictures even if you have less than 5 post. look up this thread and read thru. details are there on how to post pictures.
Posted : 01/09/2010 11:40 pm
mek
 mek
(@mek)
Re: 135gal aquarium
eto po yung last tank project ko. delivered two saturdays ago...
this is my current build. i'm on my 10th day...
thank you sir timber... hindi ko alam na pwede palang mag-post ng pics. hehe
Posted : 01/09/2010 11:51 pm
Re: 135gal aquarium
Ikaw pala gumawa ng tank na yan? Hehe sinusundan ko yan sa thread sa isang forum..ayos ah.. Wala ako waterproofing na ginamit, painted lang yung lalagyan ng aquarium.
Yan tank na yan parang playwood tank ang dating no? 2 sides not glass?
Posted : 02/09/2010 12:50 am
mek
 mek
(@mek)
Re: 135gal aquarium
dun nga po to naka-post sa kabilang forum. opo plywood tank tsaka two sides lang ang glass then the rest wood na. yung left wall kasi yun yung overflow...
Posted : 02/09/2010 8:05 am
Re: 135gal aquarium
Started the final painting already
Not really satisfied with the outcome specially the doors..so more sanding, priming and painting to come..
Posted : 04/09/2010 1:01 am
Re: 135gal aquarium
hmmmmm, chocolate... yum yum...:D
Posted : 04/09/2010 1:15 am
Page 6 / 7
