8 seater breakfast ...
8 seater breakfast table
11 Users
Re: 8 seater breakfast table
exactly what I wanted to convey... :p
ahhhhh i see. now i understand when you said that making a larger hole in the ply 🙂
Hopefully i have the right sized screw for the job
Posted : 29/12/2010 5:38 pm
place three or four screws per board, that should pull the cupped board straight...
Posted : 29/12/2010 10:31 pm
This will save my knuckles from rubbing against the underneath of my router when changing bits. Works pretty good
got this for 1,300 plus
I didnt have anyone who would push down on the boards while i screwed from underneath. Hence these heavy weights will have to do
woo hooo! getting there!
Posted : 31/12/2010 3:22 pm
i will be beveling the edge of the top and rounding off the corners
Posted : 31/12/2010 3:24 pm
Very nice Ben, I dig the floating effect but I believe you mentioned that it would still be profiled. Btw, where did you get the Bosch kit?
Posted : 31/12/2010 10:26 pm
I think i got it from ACE
Posted : 31/12/2010 10:52 pm
soon i will have my extreme router extension bro!
lapit na cguro dumating 3rd box! yehey!
Posted : 31/12/2010 11:15 pm
I think I like what Jarod said about the current profile of the table ben, I too suggest to give it as little rounding over only as possible. the floating effect would chance once the rounding is deep.
guys, the Triton router doesn't need the extension... hehehehe 😀
Posted : 31/12/2010 11:27 pm
very neat ben...what's the finishing plan?
Posted : 01/01/2011 1:09 am
oo nga eh egde work will have to be minimal. Just for ergonamics.
My bro said light/natura/grain na finish. So iam thinking using sadolin hardwoodoil (natural shade) then polyurethane. But the only stock i can find is in True value shang and its a HUGE can priced at 3K!!!
baka boiled linseed oil instead of hardwood oil. hmmm
Posted : 01/01/2011 11:05 am
do keep in mind that sandolin or any hardwood oil takes at least 7 days to dry... let alone cure.
Happy new year Ben....
Posted : 01/01/2011 11:16 am
oh... 7 days Thanks Timber! Happy New year too!
oo nga pala i might try water based wipe on poly, since i have a water based poly from ace.
So i thin it with water right?
Posted : 01/01/2011 11:29 am
i think its time for me to invest on that best in class bosch orbital sander hmmmmmmm
Posted : 01/01/2011 11:36 am
post mo naman pics Bee, haven't come across a "wipe-on" water base poly kasi... I do have Ace water base poly which I spray on, no need to thin as it is perfect in my spraygun... very nice to spray and dries in 15 minutes for the next coat...
Posted : 01/01/2011 11:46 am
the Wipe-on i mentioned is just a thought 🙂 I plan to use the Ace water based poly that you also have and then thin with 40% water then wipe on.
Not sure if it will work
Posted : 01/01/2011 12:07 pm
Page 3 / 5
