Another Audio Bench...
13 Users
Re: Another Audio Bench...
after several coats, I always scrub it with either sandpaper or scrubbing pad before the next coat is applied...
right after spraying...
and two hours later, the sheen starts to flatten....
Posted : 01/12/2010 10:07 pm
the legs are constructed using dovetail joints.
drying period na lang... delivery time na... 😀
Posted : 01/12/2010 10:09 pm
together, I was making my own audio bench and also finishing.
first poly coat...
this is how the leg assembly would look.
and happy with the initial result so far...
Posted : 01/12/2010 10:11 pm
Ready for delivery...
second coat...
the Asturo gun sprays so well, I only need two thick coats and I'm done...
I should be starting the platforms soon...
Posted : 02/12/2010 11:51 pm
Have you used the viscosity cup? How many seconds for the stain?
Posted : 03/12/2010 2:43 am
nope, everything straight from the can... stain is brushed on and wiped off...
Posted : 03/12/2010 3:01 am
What did you use the Asturo for? Clear coat?
Posted : 03/12/2010 2:02 pm
yup, satin Poly.. Moji.
was told that Narra would make good platforms for this bench. Since I have some left-overs, made the platforms and cut to dimension...
some stain and some poly and all that is left would be the spikes.... konti na lang maiuuwi ko na rin to. 😀
Posted : 03/12/2010 11:33 pm
The finish looks real smooth! You mastered it na!
Posted : 03/12/2010 11:49 pm
the Asturo was so good that this bench only needed two coats, much less than my previous works which needed some 7 or 8 coats...
Posted : 04/12/2010 12:02 am
How about the poly? How many seconds in the viscosity cup?
Posted : 04/12/2010 12:18 am
hmmm, I did not measure 😀
Posted : 04/12/2010 12:50 am
got the shelves stained.
the narra seems to blend well with the Mahogany.
first coat of poly goes in bukas... seems I have time.
Posted : 04/12/2010 11:19 pm
finished the shelves and while waiting for the spikes to arrive, I use round wooden buttons.
at least I can bring it home na...
excited to set up tonight, I get news that I have to be up bukas ng 6am... hay naman 😡
Posted : 07/12/2010 11:40 pm
I finally had time to set up... tried several positioning...
started with the amps and pre-amp getting too cramped.
move the pre amp to the top of the CDP (hope it doesn't do any bad to each other.
seems to look good and I have better control (higher and not having to lean low is a bonus)
then move the speakers a bit farther (its my current space limit until I get to fix the place)
I like the way it sounds but cramps the space a bit... really need to fix this place very soon....
Posted : 09/12/2010 1:03 am
Page 3 / 8
