Another Audio Bench...
13 Users
Re: Another Audio Bench...
gorgeous.
remove all the clutter and let it be the only clutter in the room lol!
Posted : 09/12/2010 4:55 am
brilliant.two thumbs up!!!
Posted : 10/12/2010 10:00 pm
i like the way how u used double sided tapes on four pieces of 3/4 blocks to outline the actual dimension of the tenon to be fitted in. Thats just GENIUS! 🙂
Posted : 10/12/2010 10:41 pm
thanks Ben, hope to see you sa Christmas get together ha...
Posted : 11/12/2010 1:15 am
new day, new project...
started by choosing the materials and marking the cut off lines...
cut them to rough dimensions.
then power planning one side to get a flat surface.
once all were flattened on one side, it goes to the thicknesser. here it gets a parallel side and
Posted : 05/04/2011 12:43 am
flattened on both sides.
with a no.7 handplane, I jointed one side making sure it is square to the sides.
the other side gets squared on the tablesaw...
choose the most matching boards and marked them...
Posted : 05/04/2011 12:44 am
with the no.7 handplane, the pieces to be jointed gets worked on. then glued together.
removed excess glue and kept clamped for at least two hours.
with the glue 80% dry, I start to clean the piece... with 3 handplanes and a card scraper the board came out very smooth and flat... no sandpaper was used up to this point 😀
two more of these still to follow, but that comes tomorrow...
here is the finalized sketchup... came late due to minor adjustments...
Posted : 05/04/2011 2:43 am
Wow!
That's one solid audio bench. You really don't skimp on the wood ha.
Did you put dowels or biscuits?
Posted : 05/04/2011 6:28 am
Wow!
nope, no need on side to side grain glue-up. they are pretty strong as they are...
Posted : 05/04/2011 10:10 am
What is the spray bottle for? Pampabigat? 😮
Posted : 05/04/2011 10:17 am
i think its a leveler 😮
Posted : 05/04/2011 10:44 am
Seryoso yung tanong ko. :p
Do you have to wet the wood before gluing? Parang semento na binabasa muna yung luma para kumapit yung bago?
Posted : 05/04/2011 3:12 pm
He-he. I have a similar spray bottle in my shop but it contains vinegar.
Vinegar is what I use for cleanup of epoxy on tools, clamps, and hands. I also spray vinegar on my boat jig so the dogs won't pee on them.
Posted : 05/04/2011 3:17 pm
Would you happen to notice if this also work for cats? What's your mix ratio of vinegar to water?
Posted : 05/04/2011 3:50 pm
Page 4 / 8
