Another Audio Bench...
13 Users
Re: Another Audio Bench...
here is where I left off yesterday.
cleaned the leg materials, rounded the corners and gave it its first 10 coats...
after another 10 more coats...
and then another 10 more.
then I move to the top. this is the hard part. although it looks good and finishes easy, getting it even isn't.
Posted : 09/04/2011 1:34 am
I flatten the finish between coats with a SIA sanding pad.
after two hours and a sore arm, well two arms and 20 coats of shellac. this comes out.
I think the top will be fine after another 20 more... :eek::eek:
Posted : 09/04/2011 1:35 am
brader....pwedeng pwede nako mag ahit ng bigote nyan! super mirror finish...di ka na ba gumamit ng pore filler? me nakita ako na pore filler...PYE brand. i am sure you are familiar, sa Ace lang..me brown and natural...did not buy one alam mo naman....i cant do much nowadays..my operation is nearing..just after the holiweek.
looking best...next online will be an asturo siguro..kaka enganya finish mo bro...
sige di naman yata nagmamadali client mo..dagadagan mo pa ng 30 layers!
wow!..assembolin mo na bro!
Posted : 09/04/2011 5:09 am
can you tell me more about your SIA sanding pad?
now ko lang nakita yung inlay mo sa wb....hindi tlaga mawawala ha.
ayos...how did you do it exactly?
Posted : 09/04/2011 5:13 am
Me, too. I am interested what that SIA pad is. Is it simply an abrasive pad with a foam backing or is there something special on the abrasive?
I don't have your patience in sanding. Is there a power-tool way to do this?
Posted : 09/04/2011 5:47 am
If I may, SIA is a Swedish abrasive company acquired by Bosch last 2008.
More info at www.sia-abrasives.com
Posted : 10/04/2011 12:19 am
started the day by getting all the hardware I need.
one of them are the leg levelers (a requirement for turntablists). and while I understand the necessity for them, I prefer they stay out of view, Hence I decided to drill enough for them not to be visible.
the lower hole is where the t-nut will be installed.
then the leveler is threaded in.
Posted : 12/04/2011 12:05 am
which can be raised or lowered as needed.
and as I intended, it is still out of view.
then one by one I check the shelf level against each other...
they were spot on, which makes me happy that wants me to show off some more...
Posted : 12/04/2011 12:06 am
some more polishing left then affix my signature and date of completion and its done. That should happen tomorrow.:D
Photobucket is down for maintenance at the moment, so update was delayed. anyway the rack is complete and awaiting delivery na.
and covered to avoid dust...
Posted : 13/04/2011 12:28 pm
well I did polish some more after a bit more study...
and I think it turned out... fine 😀
Posted : 13/04/2011 10:54 pm
Is that what they call mirror finish ... hehehehehe 🙂
Posted : 14/04/2011 2:16 am
I believe the correct term is French Polish or others also call it Piano finish.
but car by another name is still a car, so mirror finish would be fine 😀
Posted : 14/04/2011 2:40 am
very very nice!
awesome! do you agree with me? 😀
Posted : 14/04/2011 9:29 am
Page 6 / 8
