Balarila's Woodworking Attempts
19 Users
Re: Balarila's Woodworking Attempts
Baka merong electronics expert dito, konting tulong, pls.
I snapped the shaft of my volume pot so balak kong palitan. I don't know what the specs so I'm hoping someone here can help me para makabili ako sa Deeco ng replacement. Here are some photos.
This is the backside of the volume pot:
And the front:
I think the label says B50k. Would that mean a dual-gang 50kOhm pot?
The tone controls look the same so baka palitan ko na rin:
All together now:
Medyo mahirap pala i-solder. Masikip. Pag na-chicken ako, super glue na lang.
Posted : 24/08/2013 6:14 am
(@mannymekaniko)
Sir 50k(Kilo ohms)stereo volume control(w/o center tap)PCB mount,available po yan sa mga local electronics store best po kung dalin nyo yung sample kasi kahit di mo na sabihin ang spec. Kasi may size rin po yan pati yung haba ng shaft may maigsi at mahaba.
Posted : 24/08/2013 9:08 am
Don't forget the "B". It specifies the progression of resistance as the pot is turned.
"B" is linear daw. While "C" is reverse logarithmic... daw.
"Daw" kasi na-google ko lang din. Hehehe.
http://www.harmonycentral.com/t5/DIY-Do-It-Yourself/Differance-between-a-B50k-pot-and-C50k-pot/td-p/26568239
Posted : 24/08/2013 9:16 am
(@mannymekaniko)
Sa consumer electronics po "B" ang normal na ginagamit.I repair consumer electronics since 1990 wala pako na repair na C ang ginamit.best talaga sir dalin ung sample para pati size e sakto.
Posted : 24/08/2013 11:19 am
(@mannymekaniko)
May na encounter ako "A" baliktad ang volume ng.mixer ko imbes na clockwise ang paglakas humihina sya pag full counter clockwise naka full volume.
Posted : 24/08/2013 11:33 am
Hehehe..naalala ko tuloy tuwing may kinukutingting ako na appliances sa bahay namin,
Laging sinasabi ni misis..
Dalawang bagay lang yan..kundi mabuo o tuluyang masira:p
Bro bugel, natutuwa lang ako sa post mo, hahahaha !!! :hysterical:
NAKU Ding,
Bibilib na sana ako sa moding mo, hanep ah, kaya lang sumabit pa !!! :electricf: Naging siraniko pa !!! hahaha :bounceD:
Well, hope you get the parts soon and be able to fix that board ! GOOD LUCK !
Posted : 24/08/2013 12:36 pm
Kung papalitan mo ung mga potentiometers hanap ka ng ALPS. This is what modifiers use on this amp. Kung ala ka makita kahit ung sa Alexan na high end nila para maganda na at secured sa dust and contaminants. That will eliminate the scratching noise when you turn the knobs. Kung ala paring maganda try to check out TYSON ELECTRONICS along sumulong hiway bayan b4 you reach the stoplight of Marikina sports center. It's on your right after MINI-Stop yata yon or 7-11 coming from the foot of the Marikina bridge. Marami silang NOS na Pots na Japan made pa. sa Deeco unlesss you know the brand you need di sila masyado magaling maghanap. Kung ano nalang ang ibibigay sayo.
Posted : 24/08/2013 1:24 pm
(@mannymekaniko)
Ah!oo nga po yung Alexan na High end pots maganda rin po gamitin.
Posted : 24/08/2013 2:19 pm
Salamat! Salamat!
This forum really rocks. I get info, directions, and encouragement.
I think I will super-glue the shaft for now. That should buy me time to look for top class pots. Alps, as suggested, double-gang, linear, 50 kOhms. Titingin na rin ako ng logarithmic. Kung papalitan rin lang, better to use good quality one that will last.
Posted : 25/08/2013 4:23 am
Salamat! Salamat!
By gluing it would you mean that you intend to immediately test it after your build? My suggestion is to get that potentiometer and replace the old ones while you're at the project stage. That way the amp doesn't get too much exposure to tinkering minimizing damage especially the tubes w/c are very expensive and hard to replace. By the way, super glue is highly flammable so keep them away from your glowing tubes, in fact I'd rather not use them at all near these products.:eek:
Posted : 25/08/2013 10:09 am
Good advice, Willy.
Didn't know super glue is flammable.
Salamat!
Posted : 25/08/2013 11:28 am
(@mannymekaniko)
Very practical & very good suggestion indeed!
Posted : 25/08/2013 11:32 am
Salamat ng marami.
Posted : 25/08/2013 5:54 pm
Did some work on the amp casing. Had to do this while metalworking on my garage brackets para may "cover".
That's the amp casing. Wala pa yung case for the transformer at the top.
BTW, that table is the hall table. Aged with potassium dichromate then wiped on with green oil color. That's called the Greene & Greene finish, invented by the furniture company of the same name. I then wiped on oil on top of it. After some more oil, will wax.
Posted : 26/08/2013 9:52 am
Posted : 26/08/2013 9:54 am
Page 4 / 5
