Bed Frame WIP
11 Users
Re: Bed Frame WIP
mag next ako ng WIP for bedframe ha.il start one this week, sana naman i can have time to do this and finish by mid april.
pa post ng accessories you got from hafele. havent been there lately, havent been anywhere lately pala. hahahaha..
Hey Ernie, are you joining us later sa court? hope you can...
Posted : 12/03/2011 9:47 am
(@bigfoot2)
Re: Bed Frame WIP
Here is the Hafele part.
http://easylink.hafele.com/is-bin/INTERSHOP.enfinity/WFS/HDE-INT-EasyLink_HDE-INT-Site/en_EN/-/EUR/Haefele_ViewOfferDetail-StartSavePageable?CatalogCategoryID=rAbAqBlZuHAAAAEe86EHXCr7&ProductUUID=.aTAqBlZncYAAAEeaaMHXCtH&OrigProductUUID=pObAqBlZQ.8AAAEew_cHXCtG&SingleObjectPageableID=tx3AqBlPGZAAAAEuR1YU.Kfr&OrigArticleContext=Haefele_ViewOfferDetail-RestorePaging&OrigArticlePageableID=tx3AqBlPGZAAAAEuR1YU.Kfr&OrigArticlePageSize=&OrigArticlePageNumber=&OrigProductContext=&OrigProductPageableID=&OrigProductPageSize=&OrigProductPageNumber=&GlobalIndex=3&LinkOrigin=ArticleListProduct
Posted : 12/03/2011 10:40 am
(@bigfoot2)
Re: Bed Frame WIP
I will use twin tenons for my end rails. Its 3/4"x 7 1/2" . I will just carve one of the 2x4 legs for the mortise before laminating them.
Question:
My rail is 3/4 x 7 1/2 x 5 feet. How wide should my tenon be? Is there a minimum for the shoulder? The cheek should be around 2-2.5 inches.
Posted : 12/03/2011 7:46 pm
Re: Bed Frame WIP
You won't use bed rails anymore?
Posted : 12/03/2011 9:37 pm
Re: Bed Frame WIP
he will Moji, but will m&t the front and back portion, the rails will be used sa sides na lang daw... does make a better frame I think too.
Jun, you can cut the cheeks a little less than 1/3 the width of the stock, at least you would have more stock on the tenon. I do suggest you cut the cheeks all the way around though...
Posted : 12/03/2011 10:03 pm
Re: Bed Frame WIP
So does that mean the bed can't be disassembled?
Posted : 12/03/2011 10:18 pm
Re: Bed Frame WIP
it can be, but for the side rails only the front and back are assemblies.
Posted : 12/03/2011 10:26 pm
(@bigfoot2)
Re: Bed Frame WIP
You mean so I can have a shoulder on all four sides?
For those into bed frame WIPS, might have some good ideas here:
http://www.humbleabode.com/bedroom/bookcase-headboards-only
Posted : 13/03/2011 10:40 am
(@bigfoot2)
Re: Bed Frame WIP
Started doing the tenons.
Using a straight router bit.
I had a 2mm tearout on the top tenon, thus has to make it narrower. I will have to adjust the mortise. I will be doing the mortise with real time measurements.
I will clean up the tenon using chisels and sandpapers.
Posted : 19/03/2011 11:50 pm
Re: Bed Frame WIP
you can avoid those tear outs brader... you can use a scrap iece at the end or you can back rout. If you want to learn more, seminar ka sa kin pag free ka... jolibee lang masaya na... sa iyo ko lang offer yan ha... 😀
Posted : 19/03/2011 11:54 pm
(@bigfoot2)
Re: Bed Frame WIP
Thanks brader, don't you worry, I will always abuse your offer. 😉
Posted : 20/03/2011 11:42 am
(@bigfoot2)
Re: Bed Frame WIP
A quickie DIY sub base, makes handling the router easier.
Did the mortise, a cheat method for now. Traced the tenon on the wood, then routed and chiseled and planed and hammered and cursed until it went in. 🙂
Dry fit
Posted : 01/05/2011 11:16 pm
(@bigfoot2)
Re: Bed Frame WIP
Gluing the legs.
Joints are snug, but not perfect, some voids in the joint and glue lines. Even with the voids, the 5-inch wide tenon should still be strong enough, will just need to fill the visible vois for aesthetic purposes.
At this rate of progress, I may be finish by December. 😀
Seriously, a lot have been learned in this, the other half of the pair should come out sooner, hopefully.
Posted : 01/05/2011 11:20 pm
Re: Bed Frame WIP
You cursed until it fits huh? I should try that sometime :D... I'm very happy to see your WIP finally, its been a long wait and I can wait some more:D Looking good brader, keep em coming.
Posted : 01/05/2011 11:50 pm
Re: Bed Frame WIP
Did the mortise, a cheat method for now. Traced the tenon on the wood...
I would never treat that as a cheat. If only all mortises could be traced like that I bet most would do it as it promises a better fit. Only purists will push the idea to do it the old way coz tracing would be cheating. I would never sacrifice actual measurement versus a computed one. Why do it the harder way when an easier one is available right at hand.
I would say that what you did is a wiser method in your case.
Posted : 02/05/2011 11:08 am
Page 2 / 6
