DIY Wood Kiln - dry...
DIY Wood Kiln - dryer
13 Users
Re: DIY Wood Kiln - dryer
good am sir willyfernando
i was told then by my wife's friend, couples benjie reyes and his wife that there is a better and faster way to dry cut bamboos to be used for furnitures, and i think its through steaming inside a makeshift big drum cut in half, anyway maybe a copy of the old journal can explain it better for me so i can understand and visualize it much better. :p :rolleyes:
Hope you don't mind if its not so much bother to you, how can i get a copy of your old journal.
Thank you very much and regards too. :thanks:
hi rosy, pm sent.:)
Posted : 08/10/2011 5:26 pm
@guad,
PM SENT.... JUST TEXT ME BEFORE THE 15TH.
Posted : 08/10/2011 5:33 pm
Hi there sir willyfernando, read your PM, thank you very much !!!!!
Posted : 08/10/2011 8:59 pm
(@josephm)
Hi sir willy! Very informative indeed. May i know how much was spent on making a dyi kiln? Or is it cheaper if we buy the wood kiln dried? Thank you in advance.
Posted : 12/12/2011 10:19 pm
(@thelast)
sorry for bumping late. sir willy, i hope you received my pm. be waiting for your reply. ty
Posted : 23/05/2012 4:35 am
Hi josephm,
I'm sorry for the late reply on your query. As you know, the most important thing is that the wood you plan to use for furniture builds are Kiln dried. If you have continuous use as i do then building a dryer is a more economical and effective way of achieving production quality wood. As per current estimates, a dryer in the size I built cost around 1.5M to 2M per chamber. Mine costs around 1/3 of that as per my last estimate. I am now in the process of building a 40 footer capacity chamber. It will cook around 16,000 to 20,000 board feet of wood per 15 days when operational.
Posted : 23/05/2012 10:36 am
Hi thelast,
I did get both your email and PM. I replied to you via email from the first day you sent it to me. Pls check if it reached you or not so i may resend it if ever. tnx.
Posted : 23/05/2012 10:40 am
(@thelast)
Hi thelast,
good day sir, i didn't receive your message. had to check the spam folder to be sure and just found it. be replying later sir. ty for the reply.
Posted : 23/05/2012 5:00 pm
(@aldenlazo12)
active pa po ba to? sir willy pwede po ba makuha contact number mo? intresado po ako sa drying services.salamat
Posted : 06/01/2018 2:56 pm
(@morrissey_05)
Same sir willy. May I have your contact number for possible drying services? Thanks.
Posted : 24/05/2018 9:21 pm
Page 3 / 3
