Guitar Rack
11 Users
Re: Guitar Rack
Is this rack only for electric and thin body guitars? Looks to me that the neck slots are all of equal spacing.
Posted : 30/04/2010 7:33 pm
Re: Guitar Rack
it should accomodate 6 electric and one acoustic (tama ba yung term?). if you can see the neck portion righthand side, it has a wider starting point. yun yung para sa acoustic guitar...
Posted : 01/05/2010 12:41 am
Re: Guitar Rack
it should accommodate 6 electric and one acoustic (tama ba yung term?). if you can see the neck portion righthand side, it has a wider starting point. yun yung para sa acoustic guitar...
Re: Guitar Rack
I wanted the same color, finish and effects as the sides. so I cut the neck rest to shape on the rt. glued and clamped...
after clamping, I checked the glue coverage... perfect lang...
Posted : 01/05/2010 1:35 am
Re: Guitar Rack
so before I cut the top part to shape, it is best I stabilize it with a coat of finish. but still needing to stain before it... so here it is before and after staining...
Posted : 01/05/2010 1:36 am
Re: Guitar Rack
when the stain dried, I applied a coat of water-based poly...
here is the reason why I needed to stabilize the veneer... it is very thin and fragile...
Posted : 01/05/2010 2:19 am
(@jimny)
Re: Guitar Rack
sonny what kind of wood that's on the background with flame??
Posted : 01/05/2010 8:11 pm
(@jimny)
Re: Guitar Rack
Posted : 01/05/2010 8:13 pm
Re: Guitar Rack
are you referring to the brown one with a price tag on this picture?
if so that sir is laminated MDF....
Posted : 01/05/2010 10:25 pm
Re: Guitar Rack
meeting the guys earlier is so refreshing that continuing the rack wasn't difficult.
after a quick nap and a long mass, I start off by reducing the waste material on the scrollsaw before going to the rt.
ran the round-over bit on the inner parts of the neck part and laid-out the profile for the ends. I made a template way back when I was not busy with different round sizes, then with a knife I marked the piece.
now the difficult part, freehand cutting on the scrollsaw. and since I want a tight cut, i used a microscope.... hahahaha
I later cut the excess from the other edge, it was an inch more than I needed to keep my options open. and since the seminar was so inspiring I used my jigsaw, Bosch syempre...
Posted : 02/05/2010 1:54 am
Re: Guitar Rack
cleaned with a handplane and rounded over the rest of the corners 1st cut...
then with the correct sized router bit, I cut the final profile... top and bottom.
first coat of poly applied.
cleaning will follow and two more coats of poly... my plan is to keep the area that contacts the guitar neck as little as possible to prevent accidental damage...
cheers
Posted : 02/05/2010 1:58 am
(@drillchuck)
Re: Guitar Rack
Nice design, How Long did it take you to build this?
Posted : 02/05/2010 3:30 am
Re: Guitar Rack
six days na and counting, but free time lang of a day is what I use...if you count it in hours, it would be approx. 14 hrs. and counting...
Posted : 02/05/2010 3:57 am
Re: Guitar Rack
cleaned, sanded and coated with poly, then the same process again twice more until I was satisfied with the feel and finish.
assembled na...
made some plugs for the screw head cover...
and applied poly.
Posted : 03/05/2010 12:04 am
Re: Guitar Rack
again for comparison...
the picture of the rack we wanted to immitate...
the actual rack...
Posted : 03/05/2010 12:08 am
Page 3 / 5
