Jewelry Box 4 SWMBO
8 Users
chisel
(@chisel)
Re: Jewelry Box 4 SWMBO
Drill holes for the handle.
Attach the back.
Trace the profile and prepare to cut using my jigsaw.
Posted : 13/09/2010 11:45 pm
chisel
(@chisel)
Finish cut of the back same profile as the front.
Find this drawer a little tight to the frame.
So to remedy that a cheat a little bit by making a 1/8 groove to the side of the drawer to give an illusion of a 1/8 gap.
For the sides I used the table saw its much safer.
Posted : 13/09/2010 11:47 pm
chisel
(@chisel)
Got my gap. Did this to all drawer including the false front. 😉
Posted : 13/09/2010 11:49 pm
chisel
(@chisel)
Sanding all the parts in preparation for the finishing. Although I’m still figuring out how am I going to attach the counter top it saves me time pre finishing.
Posted : 13/09/2010 11:56 pm
chisel
(@chisel)
Its SWMBO who pick up this hardware parang baduy sakin anyways sakanya to kaya la ako nagawa including the color she loves the red mahogany stain but if I were to chose I only finish this with tung oil or shellac.
Posted : 14/09/2010 10:15 am
chisel
(@chisel)
Attach the stop block .
Try the drawer.
Posted : 14/09/2010 10:16 am
chisel
(@chisel)
Pinilit ko talaga yung tung oil sa side na lang ng drawer ko nilagay.
Posted : 14/09/2010 10:19 am
Very nice!
Ok lang yun, kahit mejo off yung trip nila sa kung ano sa tingin natin ang mas tama. Since para sa kanila yung project, isipin na lang natin na mas importante ay kung san sila masaya.
Which I believe your SWMBO would really appreciate =D
Posted : 14/09/2010 10:51 am
chisel
(@chisel)
Definitely you are correct jarod were just teasing sabi ko nga sana winie the pooh na handle na lang yung hinanap nya lol.
Posted : 14/09/2010 11:00 am
Haha! Basta kung anong trip nila!
Buting na lang madaling palitan yun mga handles, at least kung anong trip nila, pwede nila gawin!
Again, kudos to your work, I never imagined it to be complex until the final product pics.
Posted : 14/09/2010 2:41 pm
chisel
(@chisel)
Slow progress on my jewelry box still figuring out how to attach the counter top with a 95° inclination so I concentrate on the upholstery. Need to construct a plywood box insert w/c I’m going to upholster and attach inside the drawer, cut some plywood at the table saw.
Trim to size.
Posted : 22/09/2010 11:44 pm
chisel
(@chisel)
Made a shallow rabbet with the dado blade.
Assemble the pieces.
Posted : 22/09/2010 11:46 pm
chisel
(@chisel)
Test Fit need a 1/8 gap in all sides will install a foam to tightly close side gaps.
Redo my counter top because it warp dramatically with that process I reduce its thickness from ¾ down to 5/8. Then run it again to the router table to give its sides profile.
Posted : 22/09/2010 11:47 pm
chisel
(@chisel)
Sit flat on the carcase.
Now back to the problem on how I’m I going to attach the countertop. Finally I solve the problem by offsetting the hinge on the countertop. Made a jig for hinge to attach.
I used 5/8 ‘ template guide with a ¼’ straight bit.
Posted : 22/09/2010 11:49 pm
chisel
(@chisel)
Test fitting the hinge, the 1/32’ gap is intentional for easy aligning when install.
Posted : 23/09/2010 10:58 am
Page 3 / 5
