Jonathancruz WW con...
Jonathancruz WW contest entry
8 Users
Re: Jonathancruz WW contest entry
wow secretive ka rin pala...
parang si Jarod 😀 hahahaha
hahaha,slight lang sir...tonight nako mag post ng pics,busy sa work..
Posted : 29/09/2010 7:04 am
in the drill press,i bore 5/8 holes at piece f.use a power bore, from stanley.should have use bigger holes,but it's the only size i got.the size of the hole will be fine.
Posted : 29/09/2010 9:09 pm
then divide piece f to 4 pieces,and this is how it looks.
Posted : 29/09/2010 9:23 pm
then i rout the curve lines with a straight pattern bit.
Posted : 29/09/2010 9:28 pm
end result
Posted : 29/09/2010 9:45 pm
rout a1/4 wide,1/8deep groove on pieces f,to mate with the tongue on both sides of pieces e.
Posted : 29/09/2010 9:50 pm
dry fitting
Posted : 29/09/2010 9:52 pm
fitting with piece d.
Posted : 29/09/2010 9:55 pm
[IMG] [/IMG]gluing all pieces together
Posted : 29/09/2010 10:00 pm
a coat of boiled linseed oil.planning to coat it with sanding sealer,but i abort the plan,thinking i might be disqualified of coating 2 different coats,instead i recoat it again with BLO,after the first coat has dried up.
Posted : 29/09/2010 10:08 pm
after the 2nd coat
Posted : 29/09/2010 10:10 pm
side view
Posted : 29/09/2010 10:11 pm
side view .
Posted : 29/09/2010 10:13 pm
end result
Posted : 29/09/2010 10:15 pm
a view from the top
Posted : 29/09/2010 10:17 pm
Page 3 / 5
