Kitchen cabinet
19 Users
Re: Kitchen cabinet
Master ryobi-wan, tama ba yung pagka-intindi ko?
1. glazing putty on bare plywood
2. and then spray automotive acrylic paint
or meron pang intermediate step?
Posted : 19/09/2011 9:16 am
(@ricky)
After the putty you need to sand it yata muna hehehe then primer then yung paint then top coat. Sample muna sa cabinet bago tirahin yung kotse hahaha
Posted : 19/09/2011 1:22 pm
Re: Kitchen cabinet
Sanding! Oo nga pala. Hehehe.
Gusto kong paint yung chameleon. Yung nagbabago ang kulay depende sa angle ng ilaw. 😀
Posted : 19/09/2011 1:31 pm
Re: Kitchen cabinet
Or should it be primer -> glazing putty -> sand -> top coat?
Also, the only glazin putty I know is Boysen which is alkyd/oil based, not sure if that will be fine with auto lacquer in the long run.
A lacquer spot putty will be a good match with auto lacquer instead.
Posted : 19/09/2011 4:41 pm
Re: Kitchen cabinet
From [COLOR="Blue"]Boysen website:
SURFACE PREPARATION:
1. Use only kiln dried wood.
2. Countersink nail heads for putty application.
3. Sand rough wood until smooth, then dust off before painting.
4. Surface to be painted should be clean and dry, free from dust, dirt and other foreign matter.
PAINTING SCHEDULE:
1st coat : Boysen® Lacquer Primer Surfacer #305
Putty : Boysen® Lacquer Spot Putty #306
2nd coat : Boysen® Lacquer Primer Surfacer #305 on puttied areas
Final coat : Boysen® Automotive Lacquer #1300 (in required number of coats)
(Note: Add Boysen® Lacquer Flo #1205 to final coat at approximately 10% by volume as a retardant to prevent moisture blushing.)
More guides [COLOR="blue"]HERE
Posted : 19/09/2011 4:42 pm
Re: Kitchen cabinet
@jarod,
Yes, I saw that, too. But Master ryobi-wan's method is (or appears to be) different (read: matipid) and I'd like to know more about it.
Sometimes kasi you can opt not to follow the manufacturer's instruction and still get the desired results. And I'll be practicing on the mobile base for the Chin TS, so its safe try out unorthodox methods. :p
Posted : 19/09/2011 8:13 pm
Re: Kitchen cabinet
@jarod,
Tingin ko pwede naman kaya lang the adhesion may be not that strong as lacquer paint and oil putty is combined.
Patingin muna kami ng before pics ng TS+stand :whistle:
Posted : 19/09/2011 9:02 pm
Re: Kitchen cabinet
Sige na nga. malakas ka sakin, eh.:cheer:
Eto, before the stand pa lang:
Natabas ko na yung plywood. This weekend siguro ang start ng assembly.
Posted : 19/09/2011 9:46 pm
Re: Kitchen cabinet
yap tama nga yan hehehehe sanding mo muna ung plywood before apply ung glazing putty para walang rebaba di na ako nga first coat ng paint putty na agad ....1st coat ng putty sisipsipin pa ng plywood yan patuyuin mo muna ung unang coat and then 2nd coat ...is up to you kung gaano kakapal na putty ilagay mo ....after drying sanding para kuminis na parang kotse hehehe and then pag makinis na spray paint ng automotive acrylic paint ....sa automotive acrylic paint mixed mo ng acrylic lacquer tinner pang automotive din para ung buga ng spray paint pino ....matagal ko ng ginagawa yan ung una kong built na kitchen cabinet wala naman naging problema sa application na ginawa ko kahoy lang ang naging problema nabulok dahil sa water leak hehehe mas matipid yan at maganda pa 😀
Posted : 20/09/2011 4:34 am
Re: Kitchen cabinet
@ joey81,
Bro, if that is how your TS stand will look when it is fully assembled, then you've got a very useful and so practical TS stand, and daming compartments na malalagyan ng gamit. Lagyan mo lang ng doors ang two lower compartments so that tools inside may not get too dusty. :rofl:
VERY NICE CONCEPT for your TABLE SAW, so what if it is a chin ts, what is important is that it will serve and perform its functions properly. :2thumbsup:
CHEERS and enjoy working on your TS stand/cabinets project. :bounceD: :massbounce:
Posted : 20/09/2011 9:03 am
 adzz
(@adzz)
Re: Kitchen cabinet
sir Ryobi ,
pag sanding po ng plywood ,ano po grit na gagamitin ?
bale po 2 coats of glazing putty sya with sanding in between?then automotive paint na?
ano po ba ideal na ratio ng paint sa thinner?ano po yun spary gun tip na gamit nyo?hehehehe curious na newbie lang po 🙂
Posted : 20/09/2011 12:49 pm
(@zepol)
Re: Kitchen cabinet
@joey
are you using a dust collector with the TS? Kasi kung hindi, or kahit nga meron, you might want to surround the base of the TS itself, hinged if needed to access knobs and levers. That way you have less sawdust problems.
Posted : 20/09/2011 1:09 pm
Re: Kitchen cabinet
@joey
Surrounding the table saw housing will only have minimal effect because the main point of entry for saw dusts is through the opening of the insert plate. If permissible, a zero clearance insert and an effective saw dust collection is the way to go. Housing will impede noise but will cut out ventilation for the table saw as well.
Posted : 20/09/2011 2:03 pm
Re: Kitchen cabinet
sir Ryobi ,
grit 100 para sa plywood
yap 1st coat let it dry and then 2nd coat ng putty pag dry na sanding na i used 150 grit para smooth pag di ka pa satisfy apply ulit ng putty is up to you na and then spray paint
ang ideal ratio na ginagawa ko is 1/4 paint 3/4 ung thinner ... pag mataas ang automotive paint kaysa sa thinner pangit ang buga magaspang i use gravety type spray paint
@adzz
see in blue front repply thanks
:goodluck: hehehe
Posted : 20/09/2011 10:45 pm
(@rpga4433)
Re: Kitchen cabinet
additional question puwde ba lacquer flo na lang instead of lacquer thinner? if yes 3-4 rin ba yung ratio?
Posted : 22/09/2011 9:28 am
Page 3 / 4
