lazy sunday, did so...
lazy sunday, did some spring cleaning
15 Users
(@john-jo)
Re: lazy sunday, did some "spring" cleaning
Ang luwang noh? ...kakaingit...
Posted : 05/01/2011 12:43 pm
Shop pa lang buong bahay ko na...
Posted : 05/01/2011 1:46 pm
whuuups
(@whuuups)
kakainggit mga powertools mo sir =[]
http://ceejhay.net46.net/
Posted : 07/01/2011 1:20 pm
All of it were accumulated in a period of one year 🙂
I am now broke broke broke... kahit budget sa kahoy medyo hapit na budget ko 🙁
Posted : 07/01/2011 1:52 pm
Oo nga ano, ang bilis mo mag ipon for your toys... ako took three years and still want more more more... 😀
bandsaw and latheamong others are the immediate ones... after my speakers of course :p
Posted : 07/01/2011 2:18 pm
Prolly just make quick, small and inexpensive project to keep the shop flowing. Make small projects for each tool you have so it gets to be used every now and then.
Or ipahiram mo muna sa kin :p
Posted : 07/01/2011 2:50 pm
that isn't Ben's style Jarod. he has them tools so he can make gifts, ganyan kabait yan ;)... di ba Ben, malapit na Valentine, need to make something for the bossing 😀 ... cheaper to make than buy 😀
Posted : 07/01/2011 2:58 pm
hahahaha tama diyan si Timber! 🙂
Posted : 07/01/2011 8:32 pm
Finally decided that tonight is the night i will make dog holes for my workbench!!!
i apologize for my crappy camera that cant handle low light. Please bear with me
So ... i will be replacing a strip of the double plywood top with this teak... then put dog holes in it.
So prep the straight guide and start cutting away with the CS
after the plywood is detached the teak is substituted. It is proud by around 4mm
So i decided to finally USE my stanley no 4 (after 10 months of sitting there)
Posted : 07/01/2011 8:48 pm
calibrated the platform of the drill press so when i drill.. The dog hole will be 5 degrees slant
ohhh yeah... The teak is still not flush with the table there is still about 2mm
This is the first REAL time i used a handplane... my triceps hurt and my shoulders are about to give.... The blade isnt even masterfully sharpened ( i did sharpen it twice during this gruelling ordeal)
Posted : 07/01/2011 8:53 pm
i now know the value of a honing guide...
As for the dowels. I ordered from a nearby sash. sa 14th pa daw darating... sigh...
Posted : 07/01/2011 8:56 pm
finally
a better pic... i think my workbench top is due for some heavy duty sanding.
had a hard maple sitting around. This replaced the metal dog the vise came with
Posted : 08/01/2011 9:30 pm
I was making a bunch of keepsake boxes (for gifts) copied from Marc Spagnoulo of the Wooswhisperer (you guys should google the video!) last week. I also brought a box sa EB that some of you saw.
http://thewoodwhisperer.com/oh-for-keepsake/
found out that at these small tolerances there were some inconsistencies with the squareness of everything (but still acceptable aesthetically)
Then found out that my TS blade has a slight runout (eyeball) and that the friggin throat plate is 3 - 5mm lower in several places!!!
So i measured the exact height that a new throat plate has to be in order for it to be flushed with the TS. AND LO AND BEHOLD. its exactly 9mm.. so i sandwiched a 3mm and a 6mm acrylice WEEE... and there you have it an acrylic ZCI
re aligned the fence (good thing semi adjustable to) and rechecked the cross cut sled for the blade squareness after i got rid of the runout (just cleaned the arbor with some wd-40)
now i should be able to cut with precision in closer tolerances
Posted : 16/01/2011 10:08 pm
akala ko itutuloy mo handplaning your bench :D... have you tried the handplanes?
Posted : 16/01/2011 10:42 pm
i tried the block plane... grabe it glides and i get nice shavings!
the smoothing plane will be used tonight on the 8 seater table (may mga nag cup na boards grrr)
Posted : 17/01/2011 8:17 am
Page 3 / 8
