leopold's bench.
8 Users
Re: leopold's bench.
btw, does the wood need to be sealed, before the application of the varnish ?
Posted : 13/03/2011 12:46 pm
you can seal the wood using the spar urethane, then finish it with spar urethane... 😀
Posted : 13/03/2011 5:57 pm
and one big table sa center, fellowship of the ring 😀
nice and simple kuya jon, ang galing! miss u hehehe
the swmbo requested 4 more...:p :p
Posted : 13/03/2011 7:52 pm
ha ha ha...kasama ang lord of the rings...
and very easy to make...
miss you too ossie !
thanks a lot...;)
Posted : 13/03/2011 8:48 pm
ok, nice and clear...
thanks...
Posted : 13/03/2011 8:51 pm
thanks...
hindi sya clear brader. yellowish :p :p 😀
Posted : 13/03/2011 10:49 pm
koya, hows the bench? na finished na sya with spur urethane? how much per quarts/gallon? or your making another four then sabay sabay na ang finishing hehe thanks
Posted : 24/03/2011 9:47 am
joey
 joey
(@joey)
well done jonathan! bookmarked! been trying to build an outdoor bench but no idea... pagaya ha... 🙂
Posted : 24/03/2011 11:06 am
sure joey, ginaya ko lang din naman yang bench na yan,
puede mong i-widen yung "seat", instead of 2 x 8 , gawin mong 2 x 10...
planning to build 2 0r 3 more pa...:p
thanks joey...
Posted : 24/03/2011 1:12 pm
hindi ko pa na-finish, bunso 😮
don't worry, i-post ko pics pag na finish.
kailangan ko ring i finish yung bench, malapit na tag-ulan 😮
busy kasi...
Posted : 24/03/2011 1:16 pm
lagyan mo na lang kaya yung bench ng ganito para hindi anayin? what do you think? 😀
termites are not allowed
busy kasi...
Posted : 24/03/2011 11:14 pm
(@chito)
wow, this is a bench I want to build for use in front of our house, gayahin ko ah 😀
Just want to ask a question about the cutting angle. When I researched the history of the bench, the angle for cutting the legs was at 60 degrees (or 30 degrees from square). What's the primary consideration for the 22.5 degree angle? The only thing I could think of was that the bigger angle would lead to a more "laid back" seating. [COLOR="Blue"]On this site, the part the back rest is connected to is also notched, not sure if this is necessary.
What do you guys think?
Posted : 03/05/2011 7:59 pm
Just want to ask a question about the cutting angle. When I researched the history of the bench, the angle for cutting the legs was at 60 degrees (or 30 degrees from square). What's the primary consideration for the 22.5 degree angle? The only thing I could think of was that the bigger angle would lead to a more "laid back" seating. On this site, the part the back rest is connected to is also notched, not sure if this is necessary.
I think so...
Posted : 03/05/2011 9:14 pm
Just want to ask a question about the cutting angle. When I researched the history of the bench, the angle for cutting the legs was at 60 degrees (or 30 degrees from square). The only thing I could think of was that the bigger angle would lead to a more "laid back" seating. [COLOR="Blue"]On this site[/URL], the part the back rest is connected to is also notched, not sure if this is necessary.
ginaya ko lang din yan...
i think so too chito.
and putting a notch or tapered cut on the edge at the top of the back rest will modify your back posture or position, i guess any will do.
omitting the notch is fine since we love seating with a slight tilt.
putting a notch will put you on a straight back seating posture.
Posted : 03/05/2011 10:14 pm
(@chito)
thanks for the inputs guys 😀
Posted : 04/05/2011 7:02 pm
