MDF Boards Projects
70 Users
(@ricky)
Re: MDF Boards Projects
Ang ganda ^bro. Keep it up and more power to you
Posted : 03/07/2012 9:28 pm
Sink cabinet at Master Toilet & Bath
Design
Actual
Handles are aluminum. Concealed hinges are stainless steel T-304 to prevent corrosion.
ang ganda naman...
brad hindi ba delikadong mabasa yang cabinet mo?
Posted : 04/07/2012 12:35 am
Bro bryant,
Truly a work of a craftsman, I would definitely agree with bro Jayl, you are the MDF master here, no doubt about it.
Posted : 04/07/2012 8:01 am
ang ganda naman...
For this one I used 3/4" marine plywood, interior is laminated matted finish white. All corners and gap are sealed with silicon sealant to prevent the moisture and water to seep inside the board.
Posted : 04/07/2012 10:00 am
I stumbled at the home depot and found this concealed hinge by Hafele. I think during the Hafele seminar it's not yet out in the market. Only Blum Hinges has this one before. This is what I'm looking for a quality hinges " a three-dimensional adjustment, XYZ axis" in just a simple turn on screws, clip top function and soft closing.
Other hinges you need to manually pull the hinge or door to adjust.
Just by pressing the clip you can removed the cabinet door. No need for a screw driver.
Posted : 11/07/2012 8:55 pm
a close-up pic of the cabinet handles. Aluminum Matte Finish
Even the board edges is laminated. My Bosch GMR1 is a workhorse on trimming.
Posted : 11/07/2012 9:08 pm
(@imcnovicio)
bro, paki post naman ng actual picture ng board edge trimming using Bosch GMR1, or maybe HOW TO: Edge Trimming, thanks bro
Posted : 12/07/2012 11:59 am
(@pancho)
sir bryant i've always wanted to try playing with mdf ( due to the fact ang hirap ng finishing ng kahoy and plywood) one word "WOW" i wish taga iloilo ka hehehe
Posted : 20/07/2012 7:59 am
hi pancho...pangunahan ko na si master bryant...me oras pa ako today to stay in front of the pc...hehe
working with mdf has pros and cons..basing it on my little experience here they are
mdf pros:
1. cost is almost the same with a good brand locally made plywood...they are all imported coming from malaysia..unless i am not well informed.
2. can be routered to produce the edge trimming you want
3. flat
4. no voids unlike plywood
mdf cons
1. heavy...meaning to say it can be limited as doors for kitchen cabinets but not as wardrobe cabinets...if they become the latter, you need to add more quality hinges
2. fine dusts from machining these stuff can pose danger to your lungs...so be protected
3. water is their enemy..so laminating these stuff is the better thing to do..they will become almost impermeable to water.
4. they attract the growth of fungus especially during this rainy season ( and i really hate the whitish patches of fungi growing almost epidemically to involve all available surface in no time at all!)
lets wait for master bryant to chime in..for other tips
V
Posted : 21/07/2012 7:03 am
(@pancho)
hi violane thanks for pointing that out, been working with alot of hardwood since after college ( previous job ) and studying characteristics of every wood, one thing i hate about them is the finishing process and was thinking of mdf to shorten time in making stuff hehehehe ( home improvement mostly)
p.s. miss having the first one to get those premium hardwood 🙂
Posted : 23/07/2012 11:09 pm
(@ricky)
I agree with you that finishing wood is a lot harder than mdf boards UNTIL you encounter a chipped panel:eek: ang hirap i-repair. Have seen many projects na uka uka yung laminates and they just try to remedy with touch up paint, its so ugly. You really need to practice cutting them just like bryant. It's the skill that counts talaga kaya mahal din sya bec of the processing. But if you can cut it perfectly then it's worry free.
Posted : 23/07/2012 11:21 pm
Based on experienced you need to combined the following
Good saw blade + speed of cutting + depth of cut
to have a clean edge on both sides of laminated boards or minimal chipped edge.
Posted : 24/07/2012 12:20 am
(@jnazareta)
Sir bryant77,
I really admire yours works, How I wish I have the skills and talent that you posses on wood working. Sir is there any way to communicate with you over the phone? would you mind me asking for your contact number? lastly do you accept made to order? TIA..!!!
Posted : 24/07/2012 5:59 am
(@pancho)
yes the chipped in the panel i forgot about that.. hehehe back to using wood again and hardwood veneer.
but i will still try to use mdf, will not give up that easily. baka lang maka tsamba hhehehe
Posted : 24/07/2012 8:19 pm
 adzz
(@adzz)
Hmmm sir Bryant ,
So any reco po on what blade teeth count for CS ang the best na gamitin in working with MDF?and also maganda brand na blade hehehehe local or import ba?
+1 po dun sa request ni sir imcnvicio on the procedures on working with MDF . Hehehehe Baka sakali maka sunod sa yapak ng master
Posted : 24/07/2012 9:01 pm
Page 11 / 17
