Re: MDF Boards Projects
bro bryant, gaano kakapal yung wood grain laminate na ginamit mo? Before kasi I use formica laminates na madali mag-chip kapag tumatama yung gilid during transpo. Are you using the same kind or ito yung parang wall paper?
Im not sure about the thickness, I think it 0.8mm. Brand is Multiform. Unica & Italy brand madaling mag chip at mas manipis nasa 0.6-0.7 mm thickness. The best laminate you can get is WilsonArt or SIBU.
Bryant77, it is better to have system in the mess, than to have mess in the system. Nice work by the way. I live in Toledo City, Cebu, and are also planning to make a kitchen in my new house, that is when I get that fare, to much work yet. I contacted World Class Laminate and to my surprice they answered with an invitation to contact their factory in Tayud, Consolacion, Cebu. I will go there next week and hoping to be surpriced. I am going to use 15 mm melamine particle boards for the cabinets and maybe radiata pine for the doors. I think 18 mm is to heavy for cabinets. In Europe we used mostly 15 mm last time I was in business about 10 years ago.
Bryant, what do you use to cut the laminates to rough size? I tried using cutters and ang bilis mapurol..
I also using cutter blade. Tajima Blades with 14 snap-off segments, unlike the ordinary with 7 only. Para pag mapurol putol lang yun end ng blades.
hi sir bryant
ask ko lang po sir if saan po pala location nyo? hehehehe sensya na sa tanong ha ?
Project 4, QC location ko.
hehehehe
sayang sir bryant layo nyo pala , sana kung medyo lapit lang kayo ask sana kita kung pwede ko tambay sa place nyo habang me gawa kayo .
uzi mode sana ko e, curious kasi ko yung mga techniques and tips lalo na sa MDF projects mo sir.
Comparison of cut
Dull Freud blade thin kerf (left) after cutting almost 100 sheets of Melamine boards vs New Bosch Optiline 60T (Right).
Based on experience Optiline will start to dull after cutting 15-20 sheets of melamine boards.
My WIP.
Full Height Closet w/ drawers. 1220mmL x 2650mmH x 550mmD.
Color: Aluminum
After cutting the boards for side panel, doors, top & bottom and shelves.
Still a lot of boards for closet, kitchen & other cabinets.
bryant77 do you allow apprentice diyan? like to learn mo about wood working..
Sure! Why not para may assistant ako pag buhat ng MDF boards. 🙂
saan pala kayo sa project 4?
More than a week na itong WIP ko, pasensya na ngayon ko lang napicturan kung kelan patapos na.
The cabinet is for the basin type lavatory. Made of 3/4" Marine plywood with woodgrain laminate. Yun loob is finished using Boysen Enamel Paint to protect the board from moisture and water. Hole in the left is for the faucet and the other one is for the basin strainer.
Test fitting of fixtures (faucet & lavatory). Im just waiting for the 1/2" thick brown glass top na pagpapatungan ng basin.
doors not yet installed bibili pa ng soft close concealed hinges at door handles.
After installation sa bathroom ng SIL ko. The basin is seated in a 1/2" bronze glass.
Doors still WIP.
Simply elegant sir. Very nice.
