MDF Boards Projects
70 Users
(@unychorn)
Re: MDF Boards Projects
sir bry, pwede bang bumisita dyan at makita mga trabaho nyo? at mag-apprentice na din, salamat.
Mark
Posted : 04/10/2011 11:02 pm
My WIP.
Full Height Closet w/ drawers. 1220mmL x 2650mmH x 550mmD.
Color: Aluminum
After cutting the boards for side panel, doors, top & bottom and shelves.
Here's the update on the closet. Decided not to make it full height.
Need to install handles for the cabinet doors & drawers
Posted : 09/10/2011 9:39 am
Kitchen Cabinets (Overhead & base cabinets)
Doors
Melamine Board 18mm thick, color: bamboo
With aluminum continuous handle
Section of the aluminum handle.
Need to put a 2.5mm x 14mm deep groove the board to install the handle. Good thing I have Freud Thin kerf blade. I just run the circular saw at the edge of the board.
Posted : 09/10/2011 9:46 am
Bryan, the track saw kit will definitely speed you up in your work. Visit me sometime so I can show you something similar until the real thing arrives. Nice work as always, keep it up.
Posted : 09/10/2011 12:48 pm
How do you deal with walls that are not square and wala sa hulog? Im curious because it seems you cut your pieces off site.
Posted : 09/10/2011 12:59 pm
Thanks Timber. I will drop by on your place if my schedule permits. Patulong din ako sa block plane tuning. :D:D:D
Posted : 10/10/2011 9:24 pm
Moji,
Pag hindi square yun wall hindi ko sinasagad yun side ng cabinet. Naglalagay na lang ako ng filler 1-2" width to cover the gap. Pero kung 1/4" lang yun gap, acrylic gap sealant na lang ginagamit ko.
I always make sure na naka level at nasa hulog yun cabinets. Im using adjustable footing sa base cabinet at adjustable cabinet suspension fittings sa overhead cabinet. Kung mapapansin mo by module ang gawa ko ng cabinet. Overhead cabinet is divided into 4 module & base cabinet is divided into 3. After I aligned them saka ko i-screw to connect each module para tumibay. Then pag wala sa hulog yun wall yun pinadulo or outer side panel ng cabinet ako mag adjust.
Posted : 10/10/2011 9:41 pm
(@ricky)
Sir Bryan, as usual nice work. And thank you very much sa generosity mo answer our questions. More power to you.
Posted : 12/10/2011 7:17 pm
(@tinmuning)
Bryant77, for instance I wanted to have a similar kitchen counter done with a granite countertop, can I do without the concrete base? Sorry I don't have any idea where to start on our kitchen.
Oh and I read that you're from Proj 4, quite a drive from Marikina but feasible. Can you PM me your contact details?
Posted : 27/10/2011 8:24 pm
@tinmuning
Yes you can put granite countertop even without concrete base. The countertop of this will solid surface synthetic granite, 12mm thick with marine plywood under the countertop.
Posted : 27/10/2011 8:34 pm
(@tinmuning)
Really? I was afraid that marine plywood can't support the granite and the stove and all, but of course, what do I know? hehe.
Awaiting your PM re: contact details. Thanks
Posted : 27/10/2011 8:36 pm
Bryant, do you have a close up shot of the adjustable cabinet suspension fittings that you use for the overhead cabinets? What are the load ratings for one of these things?
Posted : 27/10/2011 8:59 pm
Latest update on the kitchen with some cabinet doors & continuous handle installed. The doors of the overhead cabinet on the middle will be open upward with lid stay mechanism and frosted glass insert. It will be my WIP this weekend.
Just waiting for the solid surface countertop to be installed. I'm not doing the installation of the countertop I leave it to the expert (supplier).
Posted : 27/10/2011 9:04 pm
While the PHM Boys are very busy on the Bosch Seminar last Tuesday. I kept myself busy finishing this reception table on time. Sorry no pics of WIP.
Posted : 17/11/2011 7:59 am
(@ricky)
As always, very nice work sir. Expert ka din naman sa mdf works 😉
Posted : 17/11/2011 2:27 pm
Page 7 / 17
