MDF Boards Projects
70 Users
Re: MDF Boards Projects
Looks like an alternative to Z-clips that I was wondering if locally available.
If that is all that is supporting the floating shelves, any idea how much weight can be supported? e.g., books?
I thought that to support more than just light items, one has to drive a beam/rod/bar/pipe into the wall, otherwise the pull out force on the screw is too high because moment arm (which is slightly less than shelf thickness) too small, like when prying out nails with a hammer or crow bar...
Posted : 03/01/2012 10:18 am
(@lite751)
Can't help but post and appreciate all your works boss bryant! I've been following your thread since I joined PHM and I really love your ideas. Keep 'em coming and many thanks for sharing!;)
Posted : 13/01/2012 8:23 am
(@daleiranon)
Hi, Bryan
Could I get your contact info? I have a project in mind and looking at your impressive project i would like to ask if you would be available to build me the project I have in mind.
Much thanks.
regards,
Daleiranon
Posted : 20/02/2012 2:24 pm
(@imcnovicio)
Kitchen Cabinets (Overhead & base cabinets)
Doors
Melamine Board 18mm thick, color: bamboo
With aluminum continuous handle
Section of the aluminum handle.
Need to put a 2.5mm x 14mm deep groove the board to install the handle. Good thing I have Freud Thin kerf blade. I just run the circular saw at the edge of the board.
bro ung white laminate b pre installed n o ikaw n ang nag install?pede b i apply ung same lamiate s plyboard, san nakakabili nito?thanks
Posted : 13/03/2012 10:57 am
@imcnovicio
Naka machine press laminate nya (White & wood grain). You can have wood grain both sides. But I like white inside the cabinets for neat and clean looks. Pag machine press you can order it at World Class Laminate.
If you need white laminate sa plyboard pwede naman. Manual yun pagdidikit mo using contact cement. You can get those plain white color sa home depot near your area. Or you can go to Multi-Rich Home Decor in Mandaluyong.
Posted : 13/03/2012 11:20 am
(@imcnovicio)
@imcnovicio
magkno bro ung white laminate for plyboard,meron din wood grain design for plyboard, thanks
Posted : 13/03/2012 1:15 pm
(@crazyboi_6)
Do you still accept projects? Can I have your contact info?
Posted : 05/05/2012 9:14 pm
@ Crazyboi You got Pm
Posted : 05/05/2012 9:42 pm
This was requested by a client to put a corner table with a frosted glass. I scribed first the wall and transferred it to a board to make a pattern for the glass top and send it to the glass plant.
While waiting for the glass top. I fabricated the carcass using MDF board then put woodgrain laminate (cherry) to match the existing color of furniture in the office.
Pic of carcass after trimming the sides of laminates.
Here's the finished product after installing the glasstop, shelf & cabinet door.
Posted : 06/05/2012 12:48 am
very nice work Bryan, paano mo naman sasabihin wala kang budget, dami mong projects.... dadali yan kung meron kang GCM10S... hehehehe
Posted : 06/05/2012 1:38 am
Nice, pro job.
Posted : 06/05/2012 6:36 am
(@ricky)
Ang ganda ng mga gawa mo bro. Keep it up and more power
Posted : 06/05/2012 8:31 am
No doubt .... Bryan is the forum's MDF Master. 🙂
Posted : 06/05/2012 1:57 pm
(@kulturekiosk)
Hi Bryant,
May I also have your contact info pls? I sent u a msg but not sure if you got it. Thanks!
Posted : 20/05/2012 10:29 pm
(@wdasalla)
i enjoy looking at your projects. Very beautiful. I am newbie in woodworking. any advice?
Posted : 23/05/2012 9:18 pm
Page 9 / 17
