My Commissioned Con...
My Commissioned Conference Table build...
15 Users
Re: My Commissioned Conference Table build...
ahhhhh cutting classes/work pala kayo 😛 hhehe
yari ako if i leave work 🙂 kayo na muna
Posted : 11/06/2010 1:40 am
kunwari bibili ka ng kahoy sa Mindanao ave...
hope you can join on Monday instead. Si Jay and supervisor bukas, ikaw sa Monday? hehehe :p:p:p
Posted : 11/06/2010 1:45 am
ahhaaha
i always prefer to be spectator. Will see if i can squeeze time...
Posted : 11/06/2010 2:17 am
so Monday build is a NO GO. can't commit an empty facility since it is a holiday and people tend to play on odd hours... pass by if you guys want, I will try to be there before 3pm so I can paint the rt doors...
Posted : 12/06/2010 2:18 am
the court cleared around3pm which gave me some time to work. Jay suggested a laser guide help me square up the boards. Well Bosch (c/o Golden) lent me a GLL 2-50 line laser.
tried to locate the straightest path that can offer me the biggest yield.
and with the Bosch power planner, I started cutting the material removing more in the high spots as needed.
not perfect, but very close. the cut is made only on one edge of the wood and with a no.5 Stanley scrub plane, I level it across... and I have a volunteer too...
Posted : 14/06/2010 11:56 pm
chisel
(@chisel)
Timb have you tried making a jig on your Makita thickness planner to plane a flat true surface boy that job is really time consuming I remember the days when I use the thickness planner as a jointer but only works on a 8 feet long bourd.
Posted : 15/06/2010 12:20 am
exactly my concern at the moment Chisel, these boards are 9ft long and making a bed allows me 8ft long using a single piece of ply or mdf. though my intention was to make a torsion box bed to make it stiff and joint an extension to fit my needs.
well, I would like to try this first, if it doesn't give me the results I want, I will be off to build that torsion bed... I just don't want to spend more time building another jig at this time, lots of work is needed for the raw stock (though I know it could make my life so much easier once it is set up). making that bed requires accuracy in all aspects, otherwise it is pointless to make it... kaya, wala pa akong ginawa... :p
Posted : 15/06/2010 12:27 am
High tech! Were you able to finish all the boards?
Posted : 15/06/2010 12:32 am
nope, worked on the boards we started on and finished two only of the four. then customers came to play na...
Posted : 15/06/2010 12:37 am
I see..lots more work to do still..
Posted : 15/06/2010 12:42 am
oo :p, and will be on a trip on Wednesday pa... hay naku... titigin kami ng bulkan... :rolleyes:
Posted : 15/06/2010 12:45 am
been working my butt lately... got the mahogany thicknessed. the thinnest being 1 3/4" so far... which is more than I hoped for...
Posted : 22/06/2010 3:22 am
What's the target table top thickness now Timb?
Posted : 22/06/2010 4:16 am
so far I hope I can maximize at 1 3/4" but realistic would be 1 5/8", any of which is better than 1 1/2" which was my primary target.
now, If only I can get a biscuit cutter or maybe borrow one from Chisel...
Posted : 22/06/2010 4:19 am
got one side straightened using a cs and a straight guide... tomorrow, I will square the last side with the TS. not perfect but I believe it would be very close. so I would need to start jointing, and without a biscuit joiner I decide I would use dowels. I start making a dowel jig that I can use...
and a drill with a stop...
Posted : 23/06/2010 12:39 am
Page 4 / 15
