MY First Mirror
6 Users
chisel
(@chisel)
Re: MY First Mirror
Work on the drawer yesterday also made a jig for the ¼ inch box joint.
Test fitting the hard ware.
Not a fully functional drawer because of the size its more on the design.
Posted : 21/06/2010 11:28 am
chisel
(@chisel)
Re: MY First Mirror
Apply red mahogany wood stain.
Found out that I do not have enough polyurethane so decided to put lacquer instead.
Posted : 21/06/2010 11:30 am
chisel
(@chisel)
Re: MY First Mirror
Mirror finish 2 days woodworking and 1 day finishing.
Posted : 21/06/2010 11:31 am
chisel
(@chisel)
Re: MY First Mirror
The drawer gives the mirror a character plus the hardware.
Always having a problem with lacquer it gives me this web like residue used 2 kinds of spray gun and with the same result, guys any suggestions or technique when applying lacquer.
Posted : 21/06/2010 11:33 am
chisel
(@chisel)
Re: MY First Mirror
The drawer capacity.
Back view.
Posted : 21/06/2010 11:34 am
Re: MY First Mirror
I'm sure swmbo would be very happy with it.... what is your next project?
Posted : 21/06/2010 12:43 pm
Re: MY First Mirror
It might be that your mixture has too little thinner. I used to have that problem too.
Posted : 21/06/2010 2:13 pm
chisel
(@chisel)
Re: MY First Mirror
Yaeh i agree may next project another SWMBO as requested to make a jewelry box, hmm women ha,ha,ha
Posted : 24/06/2010 12:59 pm
chisel
(@chisel)
Re: MY First Mirror
Nag 50 50 mixture nako what is the correct mixture for lacquer the manufacturer says 3/4 of the mixture. Thanks moji
Posted : 24/06/2010 1:02 pm
Re: MY First Mirror
Hmm..when i mix paint i don't really rely on ratios. You can start with 1 paint to 2 thinner but i usually go more than that on thinner. I usually go by the consistency of the mixture. I go for milk like consistency with my regular gun, when i use my hvlp mini gun i go for almost water like consistency.
trial and error lang so try it out on scrap first.
After getting the consistency of the paint right, i would suggest tweaking your material to air mixture on the spray gun. Try to search the net for the proper ways of doing this.
Posted : 24/06/2010 2:02 pm
Re: MY First Mirror
I had experienced this web like stuff too. Proper tip to air pressure adjustments solved it for me. I Increased air pressure to the gun a bit. ( 1 part paint to 2.5 thinner using a 1.5mm Tip at a consistent 32 PSI on the HVLP gun ).
Posted : 24/06/2010 4:09 pm
Page 3 / 3
