Pop up Cabinet buil...
Pop up Cabinet build...
10 Users
Re: Pop up Cabinet build...
I cut some materials for edge bands, since I want them to be bigger than store bought ones. got a new toy in the shop (will post pictures bukas) and cut the miters on it.
Timber, How are these fastened? Glued and nailed butt joints?
Posted : 15/09/2010 12:14 pm
mitered edges, and yes, glued, shot with 18ga. nails to hold them in place and clamped. since these are side grain to side grain, the adhesion is more than sufficient.
Posted : 16/09/2010 12:19 am
got the base trimmed to size added the edge bands, which I cut on the Bosch GCM 10M...
the Bosch CMS came with its own gravity rise stand (will write a review soon).
later today I added the edge bands on the short ends.
I do clamp them a bit tight...
Posted : 16/09/2010 12:30 am
got the sides cut to dimensions and ripped some edge band materials. I am leaning toward a face frame design instead of just edge-banding the sides.
help arrived again in time to sand the base and sides smooth.
the center shelf is cut to size and made spacers to ensure alignment when installation comes.
the sides are not glued yet, still at dry fitting mode...
Posted : 16/09/2010 11:27 pm
yap mas my body ang face framing than edge banding,how are you going to fasten the frame?
Posted : 17/09/2010 5:28 am
applied stain and sealer on the parts individually.
Golden seems to be very strict inspecting every single joint.
while everything is drying, we started to cut the recess for the legs.
Posted : 18/09/2010 12:35 am
strict talaga...
but he can't complain with joints like these...
more to come next week, rest time on weekends 🙂
Posted : 18/09/2010 12:36 am
I have made some progress in the pop up table today, I started by gluing the sides in place na. checked for squareness all around.
on top is the top material already in a mock up position. the back cover for the center speaker portion is still not stained.
Posted : 21/09/2010 12:20 am
yesterday I got the legs cut, drilled and sanded. and today I laied the first coat of sealer and stain.
started work on the top material as well.
and the back cover gets a coat of stain and sealer as well.
Posted : 22/09/2010 11:47 pm
then, preparing the cover for the top opening, I resawed the stock I had prepared for it.
bookmatched cut the call it.
got it cleaned and milled to size.
handplaneded the sides and started the glue-up.
added several clamps just to make sure of even pressure.
the glue squeeze out is left to partially dry and is cleaned with a chisel and a cabinet scraper.
waiting for the glue to dry, it will be cut to size soon.
Posted : 23/09/2010 2:06 pm
This shade I like so much! 8)
Posted : 23/09/2010 2:19 pm
sanding sealer and stain lang yan bro... it will v get sanded pa. 😀
Posted : 23/09/2010 2:55 pm
(@ply-user)
ganda nga ng shade nya. anong sanding sealer at stain ang gamit mo sir?
Posted : 23/09/2010 8:05 pm
I use ACE oil based sanding sealer and ACE walnut stain...
Posted : 23/09/2010 9:22 pm
Page 2 / 4
