Show your Quickie Q...
Show your Quickie Quickie Projects
22 Users
Re: Show your Quickie Quickie Projects
bore holes for the handles...
Posted : 19/05/2011 5:57 am
clamped and screwed...
Posted : 19/05/2011 6:00 am
here is the finished box...
Posted : 19/05/2011 6:01 am
then i create a rack for the mics...
then test fit a mic...
Posted : 19/05/2011 6:04 am
and here's for a quickie finish...
i apply non-grain raising stain, because it dries fast, good for a quickie projects...
NGR stain dries in seconds. unlike oil-based stain, you'll have to wait for hours to dry.
warning po sa NGR stain, these are fast drying stain, and they are suitable for use only on
hardwoods. if used on softwoods, or plywood, it will produced non-uniform results.
Posted : 19/05/2011 6:15 am
and for a quickie sealing, i apply lacquer sanding sealer.
good for spray application, kaso brush na ginamit ko, quickie kasi...:D
in a minute or so, i scuffed sanded the finish...
Posted : 19/05/2011 6:20 am
and for the top coat i apply PYE poly on the sides and hudson PU floor varnish at the base para
matibay yung flooring...;)
finished...
Posted : 19/05/2011 6:24 am
and here it is now...
Posted : 19/05/2011 6:27 am
Hey jon, that's a cute and practical rack for a number of mics, gives me an idea for one, :thumbup:
Posted : 19/05/2011 8:21 am
actually the ideas pops up, when i am making a pipe clamp rack...
:thanks: sir rosy...
Posted : 19/05/2011 8:05 pm
hey jon!
you made them proud of you once again!;)
Posted : 19/05/2011 10:28 pm
hey jon!
I bet those mics will getter better mileage too due to proper storage 🙂
Posted : 19/05/2011 10:50 pm
Kaya pala balita ko lalo mong dinamihan yung pipe clamps mo kanina umaga :naughty2:
Posted : 19/05/2011 11:37 pm
Excellent! First the guitar rack, now the mic rack. How about a video bracket para kumpleto na karaoke! 🙂
NGR stain dries in seconds. unlike oil-based stain, you'll have to wait for hours to dry. warning po sa NGR stain, these are fast drying stain, and they are suitable for use only on hardwoods. if used on softwoods, or plywood, it will produced non-uniform results.
On that NGR stain, that can that a lot of stain manufacturers use is probably the worst can in the industry. It is designed to spill half of whatever you pour out and spill onto your floor! I really hate those cans. Product inside it is good, however.
Posted : 20/05/2011 12:01 am
looking into my crystal ball, I see another Morris chair coming...:weathermanf2: but bigger:arms:
so :work: :beam:
Posted : 20/05/2011 1:59 am
Page 11 / 18
