Sister Study Table
5 Users
Re: Sister Study Table
kaya kayang maitago ng laquer primer and grains ng plywood? or kailangan kong applyan ng polituff lahat ng surface? any suggestions?
any advice from those have experience in using laquer paints..
by the way i'm painting the study table color white (smooth and glossy)
lacquer primer for wood application is usually opaque white..a couple of spray coats will defintely hide the wood grain..sand in between coats.
Posted : 01/10/2014 4:07 pm
 nick
(@nick)
thanks armand... baka bukas kapag maaraw ma primer ko na to.
Posted : 01/10/2014 7:15 pm
 nick
(@nick)
Tinapos ko na ngayung araw lang... daming delay
Posted : 20/10/2014 11:59 pm
Very nice Nick, your sister will surely like it ..did you spray it with clear topcoat pa ba or wala na.
My advice lang on your next projects: Try to plug those pocket holes specially yung mga naka expose or yung nakikita. Kung wala kang dowel na pang plug hanap ka chopstick na disposable at yun ang gamitin mo pang plug then masilyahan before painting. Also, yung mga drawer guides sana isinama mo na sa pagtakip ng masking paper before spraying paints.
Overall maganda naman kinalabasan, very functional at pwedeng ipagmalaki talaga. Good job.!!
Posted : 21/10/2014 11:31 am
 nick
(@nick)
thanks armand.. meron syang clear top coat...
yung sa drawer guides hahaha hindi ko na namask... sa ibang project na lang.
Posted : 21/10/2014 1:36 pm
Joel
 Joel
(@joel)
Nice project sir nick..
Question: yung sa edge banding ano gamit nyo? yung cabinet na ginawa ko kasi wala pang banding. btw, plyboard din gamit ko same sayo hehehe
Posted : 21/10/2014 6:58 pm
 nick
(@nick)
kahoy yun... 3/4 by 1/4... bale dikit then pako ko lang sabay trim.
Posted : 21/10/2014 9:24 pm
Joel liston ang tawag dun sa tagalog..at yun ang kilala ng mga local hardware stores. Available sizes are 1/4×2 and 1/4×3/4. Ang binibili ko is 1/4×2 then hinahati ko sa gitna mas matipid.
Joel minsan nag send ka sa akin ng private message and sumagot agad ako twice pero yung profile setting mo does not allow private messages kaya ayaw tanggapin replies ko. Nag iwan na lang ako message sa profile page mo.
Posted : 22/10/2014 5:48 am
Joel
 Joel
(@joel)
Thanks sa Reply Sir..
LISTON?
Ano kaya tawag sa bisaya yan? Meron kaya yan sa local hardware dito sa Davao? (Citi, Ace, Handyman, Wilcon)
Nakita mo ba yung cabinet project ko sir armand? (nasa kabilang site cab1net)
btw, about dun sa message nyo. di ko rin alam pano mabasa, di ko rin kasi makita hahaha. Di ko rin mahanap yung setting ng private message. tsk tsk
Posted : 22/10/2014 1:28 pm
LISTON?
Inasal.....Mang Inasal.... :joke:
Joel wala yan sa mga mall hardwaes baka sa Wilcon meron pa..pero usually available to sa mga small hardware stores.
Posted : 23/10/2014 12:09 pm
Joel
 Joel
(@joel)
bili na lang ako 2x4's tapos cut ko na lang (DIY Mode)
Posted : 24/10/2014 12:51 pm
naku matrabaho yan..
One time may ginawa ako plywood shelves ang ginawa kong liston is mga sobrang plywood backing na 1/8" lang ang kapal..para syang veneer.. di halata mas madali pa hiwain di na kailangan lagariin.
Posted : 24/10/2014 2:07 pm
(@kansismade)
Sir ano po ginamit nyo drill bit para makagawa ng pocket hole? TIA!
Pocket hole without a jig.
Posted : 03/11/2014 5:56 am
 nick
(@nick)
D ako sigurado kung spade drill bit ang tawag dun... Basta yung flat sya.
Posted : 03/11/2014 9:37 am
@kansismade: spade bit ang ginamit ni nick which is very dangerous to use..i suggest not to use this type of bit for pocket screw drilling. Try to contack JayL or check his item[COLOR="Navy"] HERE.
His drill bit is the proper tool for the job.
Posted : 03/11/2014 11:06 am
