Sister Study Table
5 Users
 nick
(@nick)
Re: Sister Study Table
@kansismade: spade bit ang ginamit ni nick which is very dangerous to use..i suggest not to use this type of bit for pocket screw drilling. Try to contack JayL or check his item[COLOR="Navy"] HERE.
His drill bit is the proper tool for the job.
use at your own risk 🙂
cons of using spade drill bit
many tear outs on the plywood...(i do not know for the hardwood) but, since pocket holes are hidden... not much of a problem
pros
-50 to 100 pesos only 🙂
Posted : 03/11/2014 10:02 pm
(@asdfgerc)
Most probably you will be using plywood to build this project. I strongly suggest to use lacquer based paints para madali and kayang tapusin in one day and wala pang amoy.
Try the following steps:
1. Spray Lacquer primer
2. lacquer putty
3. Spray lacquer primer (with sanding in between)
4. Base color of your choice (at least 3 coats and with sanding in between coats)
5. Spray Lacquer varnish (your choice of matte or gloss)
This way you will never get the orange peel texture like what you got in your kitchen cabinet. I have tried this finishing technique in my painted projects.
Again, this is just my suggestion.
Sirs pwede po kayong mag suggest ng brand/type/model para sa mga items above na ni recomend ni sir @Armand yong mid-price lang po sana.
lacquer primer.
putty.
lacquer varnish.
Tnx
Posted : 10/11/2014 6:07 pm
 nick
(@nick)
lacquer primer.
putty.
lacquer varnish.
Tnx
nung bumili akong pintura... sa paintshop ako pumunta hindi sa hardware...
yung binigay sakin na brand ng pintura hindi ko na matandaan kasi litro litro lang ang binili ko kaya walang pangalan sa lata kung anong brand ng pintura yun... basta ang alam ko mas mura sya kaysa sa boysen 🙂
Sana nakatulong... bumili ka po sa paintstore huwag sa hardware... sa hardware kasi puro branded na pintura ang nandun kaya mahal gaya ng boysen.
Posted : 10/11/2014 9:23 pm
Nick is right..bring your plan to the paint store para sila ang mag estimate..you can ask advice on procedure pa from them.
Sent from my SM-G900F using Tapatalk
Posted : 10/11/2014 10:28 pm
Page 3 / 3
