turntable workbench
9 Users
(@rolly)
Re: turntable workbench
hehe, saw this in wiredstate also, tuwang tuwa mga audiophile
Posted : 31/03/2010 12:51 pm
it was actually meant for the people at that site, but it was reserved by someone outside it...
Posted : 31/03/2010 12:55 pm
finally found some time to continue work on the tt bench...
found the materials for the top, cut in 4 feet lengths and clamped together in preparation to jointing.
drilled pocket holes to add strength alternately between the two boards.
glued, clamped with cauls too and screwed the edges together.
Posted : 10/04/2010 1:52 am
I was also able oil and stain the leg and feet with Red Mahogany stain...
shelves were oiled and stained as well...
then the legs and feet gets sealed and glazed...
Posted : 10/04/2010 1:53 am
got the legs, feet and shelves back home and assembled for fitting...(sorry for the grainy pictures, need photography lessons 🙁 )
the finish is Red Mahogany...
top will be fitted and laid-out for mortise cutting.
well its breaktime for me and now I have time to continue work on the tt bench top.
making the mortises for the leg tenons to fit into. hand cut lang para tight fit.
I use a mallet and since it is a bit heavy, I got a smaller one...
I always treat it with hardwood oil first before use.
the cut is at the desired depth now, test fitted already, I just need to trim the tenons tomorrow and gluing begins...
Posted : 19/04/2010 12:50 am
today I start by gluing the feet on...
then trim the tenon to length, using a guide...
and a handsaw...
Posted : 19/04/2010 4:01 pm
trim with a chisel and a block plane then dry fit...
a little more trimming and its glue time...
fit is perfect, tight as desired...
Posted : 19/04/2010 4:04 pm
Bro what are the board dimensions of the wood you glued for the table top? 6" x 2"?
Posted : 19/04/2010 4:56 pm
12 x 2...inches
Posted : 19/04/2010 11:58 pm
(@spyghost)
do you have a rough estimate how heavy this project weighs? do you need 2 people to carry this or just one?
Posted : 25/04/2010 8:33 am
it needs at least two people to carry it, weighs around 30 to 40 kilos...
Posted : 25/04/2010 1:43 pm
I finally had time to continue on this project, haay salamat. I need this out of the shop. I need the money for my audio hobby...
on its final stages of finishing. this is the third coat of stain.
and with flash...
Posted : 05/05/2010 12:12 am
(@bobbypage1)
I'm sure the new owner would be proud to sit his TT on it 😎
and thanks for the Bosch Sem.
Posted : 05/05/2010 5:44 am
Hey sir Ramon, welcome to pinoyhandyman. thank you for the kind words...
Posted : 05/05/2010 9:47 am
Page 3 / 4
