bandsaw suggestions needed
18 Users
joey
 joey
(@joey)
Re: bandsaw suggestions needed
Im looking for one my dear forumer... Looking for 12 up cut throat cappacity... Will be needing asap...
Posted : 10/02/2012 8:11 pm
bandsaw? asap?
get the Torq na lang...
:rose:
Posted : 11/02/2012 8:42 am
If you just need it for a small batch, you're welcome to use mine for now. Will just charge you a six-pack. I just hope you won't be cutting some ironwood-type lumber.
Best to take time to buy a good bandsaw.
Posted : 11/02/2012 10:10 am
bandsaw? asap?
:rose:
the only model ng torq that has a throat capacity that he needs cost around 97k++ iirc. the cheapest he can get is the same one Ding and I got.... a rikon 10-325 and isn't available locally :saiyan:
Posted : 11/02/2012 11:02 am
joey
 joey
(@joey)
Thanks violane!
Thanks balarila. That seems to be a good deal.
What can you say bout this guys
http://www.sulit.com.ph/index.php/view+classifieds/id/4287580/band+saw?referralKeywords=Band+saw
http://www.sulit.com.ph/index.php/view+classifieds/id/3519992/ROCKWELL+BANDSAW+FOR+SALE?referralKeywords=Band+saw
Posted : 11/02/2012 7:53 pm
for the amounts posted I think they are high, are they in working order? what parts are needed and are they still available? is the Rockwell 3-phase? seems to be missing parts and lots not in the picture. these are thing you should consider...
for the price, how much more money would you still need and how much time will it take for the parts to be available if ever meron pa... you might be better off with a BRANDNEW one, might come out cheaper and probably operational sooner.
16" or 20" bandsaws does not nec mean that is the capacity, those are the wheel sizes, best to know if these cut the dimensions that you need....
though the davis and wells bs looks real cool.....
Posted : 11/02/2012 8:35 pm
joey
 joey
(@joey)
Thanks master sonny! Thats a good point. Now its getting better, for were learning a lot here. All along i thought thats the cut size, wheel size pala yun. Now we know what to look for.
Now for your recommendation on brand new one with 16-36 vertical cut size...
Local supply please...
Is torq a good brand or theres more in binondo?
Posted : 11/02/2012 10:09 pm
brader I imported my bandsaw.... :ninja: simply bec I cannot find one that caters to a 12" cut capacity. I have seen a torq with a 20" wheel and a cut capacity around 12" and cost 96K. Sa binondo you can spend one week looking for one and come out dry, common cut size is 6 to 8" only...........
take Dings offer if you need them soon while you order abroad, it would still come out cheaper. Unless you want to buy my bs so I can upgrade to a bigger one since I have a bigger shop coming soon :toothbr1:
Posted : 11/02/2012 11:46 pm
(@fortnapz)
Sir Timb, Pm mo rin sa akin magkano bigay mo sa Rikon mo. at ng mapag-isipan heheheh
Posted : 12/02/2012 12:02 am
:eek::eek::eek: hehehe sandali lang, isisp muna ako ng pamalit ha, sabihan kita sa Eb
Posted : 12/02/2012 12:13 am
Thanks violane!
Joey,
I have the actual Rockwell series in my production and it is efficient only up to 10" even w/ Fire teeth blades. The vintage bandsaw of "isaparedes" I've seen before in his yard in Cavite and I'm afraid it's not even close to what you need. I am cutting 12-14" on a 24" flywheel w/a 5hp motor and that's the best depth it can reach. There are Taiwanese models that will fit your need but expensive. If you are on the look out for 2nd's then you may have to search in Taytay. There are a lot of shops w/ that throat capacity that have closed recently. You might stumble on a good deal by asking around. Not all bandsaw models will perform as expected even w/ a deep cut or throat capacity. It will depend on the unit's design, condition, blade specs, the wood species and operators expertise. Some of my experienced workers still break expensive blades once in a while. If you are expecting to cut a large volume of wood on a regular basis then a Brand new unit is for you. Try Golden Bell in Bonifacio Ave. in La Loma. They are listed in the yellow pages and can be googled locally. I have a RESAW that came from them. It's designed for 3" wide blades w/ a 30"- 32" flywheel diameter. It's Japanese and a beefy vintage model. Good luck and good hunting.:)
Posted : 12/02/2012 4:56 am
what are fire teeth blades? never came across nor heard them before and upon goggling I can't find any bandsaw related blades...
Posted : 12/02/2012 11:38 am
joey
 joey
(@joey)
@ timber715
Thanks master sonny! Will let you know sa Eb... Kung maabutan kopa... Hehehe..
@ willyfernando
Thanks sir! Will look for one if my time permits going there... How much did you buy the RESAW? Whats the max cut capacity?
Do you guys know the made in bulacan BS?
Posted : 12/02/2012 1:48 pm
@ timber715
no Joey haven't heard of it, is it made out of wood common to woodwoking shops locally?
Posted : 12/02/2012 2:01 pm
joey
 joey
(@joey)
Nope. Its metal. But of course i havent seen one only in picture. I saw it in one of buy sell localy if i remember right.
Can you pm me the deal for your recon... :-}
Posted : 12/02/2012 2:14 pm
Page 6 / 8
