Bosch GKS 190 Circular Saw
23 Users
(@spot10)
Re: Bosch GKS 190 Circular Saw
I already bring the inner flange to nearby machine shop cost me P250 for the machining. Know I have inner flange with 5/8" arbor. My Freud blade fit perfectly. I also bought a new inner flange cost me P180 so I can still use bosch saw blade with 20mm arbor.
Freud D0760X Diablo Ultra Finish Saw Blade cuts pretty well on MDF minimal chip-off. Already cut 2 sheets of 18mm MDF, 30 more sheets to go.
sir san nakakabili ng inner flange ive been looking at t. alonso eh wala akong makitang available panay ioorder pa daw yung part
thanks
Posted : 15/07/2011 7:15 pm
Sa Gold Tools Enterprises, E. Rodriguez cor Tuazon, tapat ng shell gas station.
Tel. No: 415-6201 . Look for Sir Winston.
Tawag ka muna bago ka pumunta. Just what I did before I pick-up the flange.
Posted : 15/07/2011 11:16 pm
(@fortnapz)
then added an L port and I can swing the hose to a comfy position.
is the dust pick movable or fixed?
Posted : 17/07/2011 11:10 am
(@spot10)
mga sirs wala na po bang may idea sa inyo kung saan pa meron available i cald gold tools hindi na daw available
thanks
thanks din kay sir bryant
Posted : 26/07/2011 11:32 am
thanks
Sa Kamagong st sa Makati meron yan. Bosch service center. paki look up na lang contact details either in yellow pages or online....
Posted : 26/07/2011 12:32 pm
fixed yan brader.....
New blade for my GKS 190, Bosch Optiline 60T with 4 pcs ring spacer (20mm/19mm/16mm/5/8").
Need to replace my 7 1/4" Freud blade, hindi na maganda ang cut sa melamine boards....after cutting 100 sheets of 3/4" thk 4x8 boards.
Posted : 15/09/2011 8:46 pm
(@vyrus626)
sir bryant, is this blade locally available? how much? thanks!
Posted : 16/09/2011 3:32 pm
I got the Bosch Optiline at Gold Tools Enterprises for P530.
Posted : 16/09/2011 7:18 pm
 adzz
(@adzz)
mga sirs ,
any idea po sa price ng Bosch GKS 190 or Makita 5008MG sa Panda?
me kasama na bang blade to ?
between sa 2 kaya alin magnada performance wise?any pros and cons?
any other brand to suggest?
Posted : 23/10/2011 11:44 am
mga sirs ,
do you need the extra capacity of cut? the 5008MG is an 8 1/4" CS while the GKS190 is only 7 1/4". I have both and bought my 5008mg over two years ago and was used for cutting thick rough wood, but with other tools on hand now, I hardly use it. I now generally want something lighter since I use the cs mostly for sheet goods. the GKS165 or 6 1/4" fits me fine.
Posted : 23/10/2011 1:54 pm
 adzz
(@adzz)
thanx po sir timber ,
actually sir was planning to use this in my planned cabinet makung projects which i think i will use MDF or marine plywood.
as of now i am still in the process of canvassing and planning stage on the tools i will use.(same as ipon mode hehehehe)
was checking the sulit and found some brands like Ozito ,powercraft and Ryobi and some more so some help and feedback on this brands is greatly appreciated especially from you woodworking gurus 🙂
salamat po uli
Posted : 23/10/2011 6:53 pm
if you intend to use it for a long duration and want support for your tools choose Bosch, Makita or even Dewalt. Save a bit for a good quality tool, as they should serve you long. If you want to save naman and don't really think you need the tool very long, a good brand usually sells better secondhand or you can look for freinds whom you can borrow from for a smallish build.
Posted : 23/10/2011 7:50 pm
 adzz
(@adzz)
sir timber ,
i intend to keep my tools for a long time naman kasi e, but definitely not for business application naman e .
any idea for the prices of this brands? was checking the price on sulit and quite interested sa mga "other brands " na nga e hehehehe (price conscious hehehehe)
Ozito and AEG , any feedbacks?
Posted : 23/10/2011 8:16 pm
sir timber ,
Between Ozito and AEG I would choose AEG any time of the day but that's just me.
Posted : 23/10/2011 11:13 pm
Page 3 / 5
