Clamps and vises thread
29 Users
Re: Clamps and vises thread
Bessey clamps, my favorite. They're always the first ones I grab when gluing my work.
I like them because I can use them up to 100" length with the use of extenders.
bought from amazon
http://www.amazon.com/Bessey-KRX2450-Fixed-Jaw-Parallel-Clamp/dp/B001HSO6WC/ref=sr_1_6?ie=UTF8&qid=1314806454&sr=8-6
Where are these clamps made?
Posted : 01/09/2011 12:09 am
 camv
(@camv)
JayL,
honestly I didn't bother to read the literature hehe. I'll take a look when I get home if I still have it.
Posted : 01/09/2011 12:19 am
Saw at Han's last month, P178 and P198. Being Löta, I assume Panda would have these, anyone seen?
There is a spring at the pivot point but it is for opening the clamp, unlike in a spring clamp. The adjustable force for closing seems to be from bending of the plastic.
The cardboard says: You Can Simple Control , Adjust Pressure The Force.
Light
Increase
Heavy Duty
Push it
Quick Release
Posted : 28/11/2011 12:37 am
Was "coaxing" a 3/4-inch thick plank of bowed kamagong into a straight edge with this clamp.
Lesson: Have the patience to steam wood. Or have the money to buy a jointer.
Posted : 14/12/2011 4:40 am
(@fortnapz)
HI Guys! Open ba ang panda kung sunday! bibili sana ako ng pipe clamps!
Posted : 18/02/2012 9:02 pm
sarado brader.............
Posted : 18/02/2012 9:29 pm
Or use Wilton Drop Forged Steel C Clamps ... I presume the wood you are working on is easier to straight bend than 1/2" thick mild steel.
I'm done with KYK ... unless for very very very light duty work .
Panda has Wilton and the prices are very competitive.
Posted : 18/02/2012 9:34 pm
Groz Parallel Clamps
If you are into building cabinet doors and or edge jointing some nice planks then parallel clamps cant just be beat.
Although i am not a fan of Groz handplanes (mediocre build) one of our member while window shopping from our favorite store chanced upon these new arrivals months ago.
There are two models depending on the length but i chose the 24 inchers for my preference, building wise.
The face plate is hard plastic, gray black as oppose to the green, red or blue ones from the leading brands (Bessey, Irwin).
For the 24 inchers, the 6" Bessey Uniklamp is pale by comparison in all aspects
3/8" thick solid metal body
at the ends are foot rest which are helpful to balance the weight of the clamp when clamping boards less than 1 foot.
the top shows the foot plastic at rest and below when it is in action
Posted : 03/04/2012 6:32 am
the turning knobs are not wooden but of the same built as the metal bar with deep set threads.
although 24", an allowance of 1" is provided to give you space when aligning the boards making a max room of approx 25".
and of course , let me try show you how it will work.
each 24" clamp can be had for 1500p++ i just needed two.
V
btw: i hope our favorite store will give us incentive when we promote their stash!!!
Posted : 03/04/2012 6:38 am
@V
I'm having a hard time trying this phrase this question so I better shoot it direct.
Do you think this particular Groz product is at par or maybe even better than the Bessey ( apples to apples ).
Bessey does manufacture in India now. The welding magnets I got from them were made in India.
Posted : 03/04/2012 11:15 am
bro, the Bessey uniklamp 6" model is a lightweight duty parallel clamp and i did some injustice to the Bessey camp comparing it to the 24" incher Groz!:(
i cant say much between Groz and its real counterpart, which perhaps now is the Revo body of Bessey.
my only concern is the hard plastic face plate which is relatively thin at approx 1.5mm.
in itself, the clamp is well built.
i hope moji (who has a set of Revo) can give us an in depth review.
V
Posted : 03/04/2012 5:24 pm
(@gregg)
where is this Panda in Araneta Ave. or in Binondo loated? Thanks
Posted : 19/07/2013 4:44 pm
horge
(@horge)
http://www.yellow-pages.ph/maps/panda-construction-supply-incorporated-2
http://www.yellow-pages.ph/maps/panda-construction-supply-incorporated-3
Fair warning: the branch on Araneta Avenue is very easy to miss (the store is
a lot narrower than most expect it to be), so keep your eyes peeled.
Posted : 20/07/2013 7:29 am
@ gregg,
HAHAHA, be sure when you go to any of the Panda stores, you have enough cash to spend on tools, sigurado ako, kulam to the max aabutin mo 😮 sa dami ng tools/gadgets that you will see !!! LOL 😀
Posted : 21/07/2013 10:21 am
I bought this a month ago..since i can't find a aluminum rail for my supposed to be drill press table project so i do not have any option but to find an alternative to make boring holes easier using my drill press..
[IMG][/IMG]
A X-Y vise some call it cross slide vise for drill press..
[IMG][/IMG]
Dirty,greasy and ugly..i need to dismantle all parts to clean and paint it para masiyahan naman akong gamitin..
[IMG][/IMG]
After cleaning..
[IMG][/IMG]
Posted : 02/08/2013 9:22 pm
Page 8 / 10
