DIY Bandsaw
12 Users
Re: DIY Bandsaw
Armand, Let me show you what our dear friend Dr. Jonathan Cruz saw in my shop. We slice around 20,000 board feet of wood per month. I think that'll give you an idea of how vast our experiences are with BS's and how we work our way around issues like yours and many others. Just take the time to learn the techniques we have developed in processing while you have the opportunity much like how we helped Bro.Jonathan with his church door build. He now has extensive knowledge in base production and finishing. It is now up to him to develop it whether for DIY or business.
Yes Willy I'm looking forward to see your shop one of these days. Hoping to learn too what jonathan learned from your experience and from your production set up. This is a rare opportunity and I feel so grateful for having this chance you offered.
Posted : 10/07/2013 10:12 am
Re: DIY Bandsaw
Anytime Armand.:thumbup:
Posted : 10/07/2013 11:19 am
(@dimitris)
Re: DIY Bandsaw
Armand how did you make the hole through the frame for the square steinless steel of the upper blade guide?
Posted : 11/07/2013 5:40 pm
Re: DIY Bandsaw
Use circular saw and make a groove or dado cut. The width should be slightly larger than your tube but the depth shoud be almost double the width of your square tube. Then after cutting the groove you put your square tube then you cover again with wood the extra space. Hope you got it.
Posted : 11/07/2013 8:21 pm
Re: DIY Bandsaw
Yes bro Armand, clicked the thread and saw the build, can that be considered as a poor man's band saw. Nevertheless it looks so sturdy since most if not all are welded metals for its support.
I have a question bro with regards to the cutting blade, this could be a stupid question from a none wood worker. Doesn't the blade wander from left or right during the process of cutting lumber ? Doesn't the wheel have a sort of a groove or canal to prevent any wandering that may cause blade slipping. Please enlighten me on this matter bro, just not really sure of the groove thing for the blade.
Thanks in advance bro Armand ! 😉
I wanted to post this link a long time ago. Only now I had the chance.
Its a very good explanation why the blade stays on top of the crown.
http://woodgears.ca/bandsaw/crowned_pulleys.html
Posted : 13/07/2013 1:22 pm
Re: DIY Bandsaw
A [COLOR="Blue"]video update of my Band Saw. Yakal wood was used for the first test cut.
Finally it is up and running na and the only thing I can say is " Sweet" ..so sweet. Ang sarap lalo mag woodworking, mas tahimik kesa sa Table Saw ko and mas matipid sa kuryente coz 1hp lang ang motor. It is now my favorite cutting tool with almost endless possibilities when paired with my jointer. Nag linis tuloy ako ng shop just to make a dedicated space for it.
Now ready for the cabrioles.
Posted : 30/07/2013 10:33 pm
Re: DIY Bandsaw
Awesome, Armand.
That's the ultimate: woodworking to create a fine woodworking tool. Bandsaw pa!
Posted : 31/07/2013 4:24 am
Re: DIY Bandsaw
Wow! Ang galing mo sir armand..
Ang bilis mag cut diretso pa..smooth na smooth..
Ibang level na ang diying skills mo!::groupwave:
What is cabrioles?:confused:
Posted : 31/07/2013 7:21 am
Re: DIY Bandsaw
he he..I meant cabriole leg. Those shapy legs of an oldie pole dancer..it looks like this:
@balarila: Ding..yess, joy is a well tuned band saw. Thanks
Posted : 31/07/2013 9:17 am
Re: DIY Bandsaw
A SUPERB DIY PROJECT bro Armand indeed if I must say so !!! :clap1: :2thumbsup:
:1stplace: :groupwave:
Posted : 31/07/2013 10:25 am
Re: DIY Bandsaw
Thanks rosy..gawa ka na din...sa kahoy ako, sa bakal ka naman..;)
Posted : 31/07/2013 11:16 am
Re: DIY Bandsaw
HAHAHA, how I wish I have that knowledge and courage to do a band saw for metal though I really want to have a horizontal band saw for precise metal cutting. I have seen some shown in you tube but maybe in time when I have done enough research and probably know where to source the cutting blades and flywheels.
Again congrats on a well done band saw !!! saw the video last night and the cut on that piece of wood on the first test cut was really very clean, smooth and precise. Iba talaga pag ang band saw ay well tuned with well sharpened blades. :thumbup:
Oh, when the time comes that I go into the route of wood working, I will look for your diy tool projects sa forum for reference and guidance.
CHEERS :cheers:
Posted : 31/07/2013 12:04 pm
Re: DIY Bandsaw
HAHAHA, how I wish I have that knowledge and enough courage to do a band saw for metal though I really want to have a horizontal band saw for precise metal cutting. I have seen some shown in you tube but maybe in time when I have done enough research and probably know where to source the cutting blades and flywheels.
CHEERS :cheers:
Posted : 31/07/2013 12:05 pm
Re: DIY Bandsaw
anytime rosy, but don't forget I owe @willyfernando a lot for his inputs during the construction so you might also need his advice when that time comes. ( I still haven't personally thank him yet :)).
Posted : 31/07/2013 10:04 pm
Re: DIY Bandsaw
This one is all you Bro Armand. You just gave us the opportunity be involved with your build so we are the ones thankful kasi parang kasama narin kami gumawa.:2thumbsup::clap::choir:
Posted : 01/08/2013 12:58 am
Page 8 / 9
