Handplanes thread....... show what you have.
21 Users
Re: Handplanes thread....... show what you have.
the previous pics weren't very nice since I used a cellphone camera for it only, I decided to make a short video so you can hear the cut as well.... My Handplane Cuts
Posted : 28/02/2012 11:58 am
Brother ikaw na pinaka malupit na nakita kong mag setup ng mga hand planes dito ..... hehehhehhehe
Posted : 28/02/2012 3:23 pm
Di ko kaya level ni Jarod with his LN's tapos si Ryobi naguumpisa na magcollect ng mga malulupit na Handplanes... in another EB I can share how to sharpen and handplane 101 ulit....
Posted : 28/02/2012 3:46 pm
Good idea yan bro kasi madami ng meron nung honing jig. Demo mo na din bago mo na diamond stone .... 🙂
Posted : 28/02/2012 4:41 pm
grabe ang lupit,
swabeng swabe ang himas, walang halos kumukontra,
ang kinis ng result, flawless !:jeanie:
may handplane kapa bang ginagamit na stock ang blade ?
Posted : 29/02/2012 5:41 am
grabe ang lupit,
lahat ng handplane ko stock ang blade except yung bedrock 607. yun lang naka-Hock.
Posted : 29/02/2012 10:00 am
these planes arrived today, a no.7 for Bigfoot, and a Bedrock 606 and a Keen Kutter K7 for me...
after assembly, they joined the rest of the group...
in one room I hope they mingle and multiply some more... Lol.
this one is looking for Jon.....
I miss my handplanes.....
Posted : 26/09/2013 2:34 am
(@arrowspas)
Sir Baguhan lang po ako sa Hand Plane. Tanong ko lang po. Ano anu ba un mga dapat malaman sa Spec ng Hand Plane. Ano po ba un mga Number at dapat ko malaman sa pagbili nito. salamat mga idol.
Posted : 30/09/2013 11:26 am
horge
(@horge)
IIRC, those numbers are adopted from the old Stanley numbering-system for handplanes.
1 for Low Angle Block, 2-4 for Smoothers, 5 for Jack (as in, all-around "jack of all trades")
and 6-upward for Jointers.
Minimum for me would be one Low Angle Block plane, one Jack plane, and a Jointer plane.
If you buy low-end units (Eagle, etc), make sure you dress the soles (the steel underside
or "face" of each plane, and by 'dressing', I mean get the sole flat and smooth), because
low-end units invariably have uneven soles.
You basically remove the blade, color the entire sole with a permanent marker, lay down a
sheet of fine sandpaper (face-up) on the flat piece of thick float glass or countertop marble
or granite, place the plane sole-down on the sandpaper, and move the plane back and forth
to sand the sole flat. Any dips in the sole will remain colored by the marker, and you want to
keep on going until no marker-color is left. The blade will obviously need some first-time TLC
as well.
I did this for an Eagle #3, and was satisfied with the resulting performance, considering how
cheap it was (the handles were varnished crap and the lever cap was poorly cast, however,
and needed separate corrective work)
Just my 2
Posted : 07/10/2013 1:11 pm
Page 9 / 9
